Realistic Top speed of a 914 |
Jason 914-6 |
Apr 25 2017, 01:57 AM
Member Group: Members Posts: 57 Joined: 7-November 04 From: Australia Member No.: 3,069 |
Hi might be a dumb question but how fast do you think a 914 with a six or four in could go I'm talking like land speed fast. (IMG:style_emoticons/default/evilgrin.gif)
Not a race car with spoilers/wings etc. but a narrow body low slung with tall gearing. Any thoughts other than I'm (IMG:style_emoticons/default/screwy.gif) But the Gt class here in Australia is a soft record ( 2lt class and 3lt) and well !!!!!!!!! (IMG:style_emoticons/default/drooley.gif) |
Jason 914-6 |
Apr 25 2017, 08:15 PM
Thanks for the input, If I run as a G/GT its an open record, so if I just run in that class it's a record (IMG:style_emoticons/default/biggrin.gif) Also none of blown records have ever been run so gives some scope to play some more, with a turbo combo. (IMG:style_emoticons/default/evilgrin.gif)
Engine Class Breaks A 103 440 - 500 cid (7.21 L - 8.19 L) B 104 373 - 439 cid (6.11 L - 7.19 L) C 105 306 - 372 cid (5.01 L - 6.10 L) D 106 261 - 305 cid (4.27 L - 5.00 L) E 107 184 - 260 cid (3.01 L - 4.26 L) F 108 123 - 183 cid (2.01 L - 3.00 L) G 109 93 - 122 cid (1.51 L - 2.00 L Blown Grand Touring Sports - /BGT Class Entry Driver Year Speed (mph) A/BGT B/BGT D/BGT E/BGT F/BGT G/BGT H/BGT I/BGT J/BGT TOP Unblown Grand Touring Sports - /GT Class Entry Driver Year Speed (mph) A/GT B/GT C/GT D/GT E/GT Phil Shephard 2015 (2010, 2009, 2004) 170.068 (161.870, 149.253, 146.127) F/GT Stephen Bridge 2010 139.919 G/GT H/GT Hugo Halls 2013 80.504 I/GT J/GT The class rules Grand Touring Sport: /BGT, /GT (Gas Only) Series production sports cars and coupes, as well as limited production cars by a recognized automobile manufacturer, which are primarily intended for comfortable high speed touring. At least 500 of the same model must have been produced. This category does not include cars with rear seats suitable for continued adult occupancy. The following items must be retained in stock location and of the same year as the body: frame, fenders, hood, grille, drip rails (must not be filled), windows, door handles, window trim, headlights (high and low beam), tail lights, parking lights, stop lights, radiator, both bumpers and horn. Stock gas tank must be fitted, but need not be used. Any transmission, non-quick change rear end, and starter capable of starting engine may be used, as long as the original running gear design is retained. Independent rear suspension may be replaced with any non-quick change rear end. The following body and chassis modifications may be made: wheel openings may be radiused, generator may be removed and any exhaust system capable of being closed off may be used (no individual stacks). Air dams and air spoilers identical to factory optional equipment for the body in question may be added, bucket seats may be used (as long as original side panel upholstery or equivalent remain) minor chrome trim and emblems may be removed, and air scoops may be used. Stock windshield may not be removed or lowered. Any tarps must be nonrigid. Engine swaps are permitted, as long as they are of the same manufacturer (e.g., Ford into Ford, Porsche into Porsche, etc.). This class may run nitrous oxide, but will be advanced two (2) engine classes. The following are not permitted: streamlining, belly pans, air ducts, air vents, headlight air scoops, chopping, channeling, quick change rear ends, stepped frames, exhaust outlets through the front fenders or hood, blocked off grilles or radiators, engine relocation, body and interior gutting, taped body or window seams. Rules for this class will be strictly enforced to ensure that cars entered herein are typical of street machines which may be purchased from an automobile dealer. Engine classes allowed are: AA, A, B, C, D, E, F, G, H, I & J Body Code Body Class Description 314 BGT Blown Grand Touring Sports 337 GT Unblown Grand Touring Sports |
Andyrew |
Apr 25 2017, 09:44 PM
The following body and chassis modifications may be made: wheel openings may be radiused, generator may be removed and any exhaust system capable of being closed off may be used (no individual stacks). Air dams and air spoilers identical to factory optional equipment for the body in question may be added, bucket seats may be used (as long as original side panel upholstery or equivalent remain) minor chrome trim and emblems may be removed, and air scoops may be used. Stock windshield may not be removed or lowered. Any tarps must be nonrigid. Engine swaps are permitted, as long as they are of the same manufacturer (e.g., Ford into Ford, Porsche into Porsche, etc.). How bad ass do you want to go? Is the 914 qualified as a Porsche or a VW in your area? IF its a VW you could run the same engine swap that I am running (Audi 1.8T) and pretty much put as much power as you want into the chassis like Im doing.. If its Porsche you could run the VR6 motor from the Porsche Cayenne, build it, turbo it and make 1XXXhp... |
Jason 914-6 |
Apr 30 2017, 06:39 PM
The following body and chassis modifications may be made: wheel openings may be radiused, generator may be removed and any exhaust system capable of being closed off may be used (no individual stacks). Air dams and air spoilers identical to factory optional equipment for the body in question may be added, bucket seats may be used (as long as original side panel upholstery or equivalent remain) minor chrome trim and emblems may be removed, and air scoops may be used. Stock windshield may not be removed or lowered. Any tarps must be nonrigid. Engine swaps are permitted, as long as they are of the same manufacturer (e.g., Ford into Ford, Porsche into Porsche, etc.). How bad ass do you want to go? Is the 914 qualified as a Porsche or a VW in your area? IF its a VW you could run the same engine swap that I am running (Audi 1.8T) and pretty much put as much power as you want into the chassis like Im doing.. If its Porsche you could run the VR6 motor from the Porsche Cayenne, build it, turbo it and make 1XXXhp... Was thinking more along the factory hot rod line. sort of like a 916 clone and run a 3.0 engine. (IMG:style_emoticons/default/aktion035.gif) The car is know as Porsche down here (IMG:style_emoticons/default/biggrin.gif) and because there aren't many around not many would know what the hell it is or should be. (IMG:style_emoticons/default/shades.gif) I have an ex race car shell that I could loan my 914-6 bits to, and run the 2.0 class while the 914-6 body is being derusted (IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 16th May 2024 - 07:22 AM |
