Replacement Relay Socket Panel, Updated: Version 3 - Solid State Relays and Fuse Panel Replacement |
Evan0 |
Apr 30 2017, 10:12 AM
Newbie Group: Members Posts: 44 Joined: 13-February 17 From: Southern California Member No.: 20,837 Region Association: Southern California |
Update 3 Post
I've been rewiring my car for the last few weeks and part of that was replacing the factory fuse panel with one that uses modern fuse from JWest Engineering. I was unhappy with the existing relay sockets that I found. As a result of that, I designed and printed a monolithic fuse socket for all the relays, buzzer, and flasher unit. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-20837-1493568735.1.jpg) After mounting it to the fuse panel. The buzzer is a Hella H35394001. The horn, blower, and fog relays are Hella 933332051. The flasher unit is a Hella 009492101. The head light relay is a modern reproduction of the VW one. Still waiting on the flasher unit to ship. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-20837-1493568735.2.jpg) I'll be posting the STL files, Bill of Materials, and instructions after I've worked out a few kinks. I would love any feedback or suggestions on improvements. |
euro911 |
Aug 14 2017, 11:12 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,849 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Very nice, Evan. With the solid-state relays you've employed, will this cure the load issue when running LED turn signals?
Also, this unit is all that's needed to supplant the J-West or Engman fuse blocks and relay unit(s)? If you're still looking for guinea pigs ... I'm your huckleberry (IMG:style_emoticons/default/laugh.gif) |
Evan0 |
Aug 14 2017, 11:33 PM
Very nice, Evan. With the solid-state relays you've employed, will this cure the load issue when running LED turn signals? Also, this unit is all that's needed to supplant the J-West or Engman fuse blocks and relay unit(s)? If you're still looking for guinea pigs ... I'm your huckleberry (IMG:style_emoticons/default/laugh.gif) It doesn't have the load issue with LEDs, but it does require that the turn signal indicator lamp be replaced with a LED bulb as well. It's a annoying limitation of the design. The integrated fuse and relay panel would be all you needed. |
Lo-Fi Version | Time is now: 18th May 2024 - 09:44 PM |
