Replacement Relay Socket Panel, Updated: Version 3 - Solid State Relays and Fuse Panel Replacement |
Evan0 |
Apr 30 2017, 10:12 AM
Newbie Group: Members Posts: 44 Joined: 13-February 17 From: Southern California Member No.: 20,837 Region Association: Southern California |
Update 3 Post
I've been rewiring my car for the last few weeks and part of that was replacing the factory fuse panel with one that uses modern fuse from JWest Engineering. I was unhappy with the existing relay sockets that I found. As a result of that, I designed and printed a monolithic fuse socket for all the relays, buzzer, and flasher unit. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-20837-1493568735.1.jpg) After mounting it to the fuse panel. The buzzer is a Hella H35394001. The horn, blower, and fog relays are Hella 933332051. The flasher unit is a Hella 009492101. The head light relay is a modern reproduction of the VW one. Still waiting on the flasher unit to ship. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-20837-1493568735.2.jpg) I'll be posting the STL files, Bill of Materials, and instructions after I've worked out a few kinks. I would love any feedback or suggestions on improvements. |
raynekat |
Jul 19 2017, 08:30 PM
Advanced Member Group: Members Posts: 2,157 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
I have to agree with Jeff Bowlsby on the after market fuse panels.
I'm doing a 914-6 conversion on my 1971 914-4 and I'm using an NOS 1971 chassis wiring harness. I've also got a JWest aftermarket fuse panel. The way this panel works is that the wires on the "inlet" and "outlet" sides of the fuse come in on opposite sides of the panel. Where in the factory panel, the "inlet" and "outlet" wires come in on the same side of the fuse panel. THAT IS A BIG DIFFERENCE WHEN IT COMES TO PLUGGING ALL THESE WIRES IN. I'm seeing that there is a lot of stress on the connectors with the JWest panel and the main harness kind of straddles the panel vs being in behind the panel with the factory setup. So I've decided to ditch the JWest with the new style fuse in lieu of the old fashioned factory style. I can just tell the factory will be a much better setup. Obviously the factory knew what it was doing. |
Lo-Fi Version | Time is now: 5th May 2024 - 04:31 PM |
