Transmission cooler Help..., Not sure where to Tap |
joea9146 |
May 9 2005, 06:24 PM
Senior Member Group: Members Posts: 663 Joined: 10-February 03 From: Denver, NC Member No.: 283 Region Association: None |
I am installing a Tranny cooler... I got the fittings to fit the drain and fill plug .
Everything was going fine until I got under the car. The Throttle linkage for the 6 blocks the drain plug. So I was going to tap the case next to the plug and insert the fitting there. My only apprehension is the case in that area has a slight bevel where I want to tap it... Any ideas or other suggestions. Attached image(s) |
joea9146 |
May 9 2005, 06:25 PM
This is where I was planning to tap it.... Is this a good spot interference wise ?
Also the slight Bevel.... in the case (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) Attached image(s) |
TimT |
May 9 2005, 06:38 PM
That is a rather large fitting for transmission cooling.. you may have a problem with tappin into that arear of the transmission.. a gear cluster lives near there..
get a smaller fitting, and tap the case on the other side of the drain |
joea9146 |
May 9 2005, 06:42 PM
Tim ... do u mean the oppisite side of the case ? |
TimT |
May 9 2005, 06:49 PM
yes on the other side of the case. the drain on the 914 tranny is passenger side.. take your oil from the drivers side.. if you are in the same plane as the drainplug, you wont have to worry about interference with gears etc..
iamchappy |
May 9 2005, 07:05 PM
This is how I did mine if it helps I am using a different throttle bracket which dosen't interfer.
I used the fill and drain plugs by tapping an 8AN fittings into them. Attached image(s) |
iamchappy |
May 9 2005, 07:06 PM
cc
iamchappy |
May 9 2005, 07:08 PM
ttt
Aaron Cox |
May 9 2005, 07:09 PM
can you tap the plug itself? or use an angled (45 or 90) fitting?
iamchappy |
May 9 2005, 07:12 PM
I know its hard to see but the bottom fitting going into the lower drain plug is a 45 8AN to 3/8 pipe thread fitting.
8AN I am sure is big enough for a trans cooler the pump sucks it through like a shop vac. |
iamchappy |
May 9 2005, 07:18 PM
I can get you another picture if you like, the transmission is out of the car right now.
joea9146 |
May 9 2005, 07:25 PM
Another picture would be good from the tranny case to the outside of the fitting is how many mm if possible to measeure |
LukeD |
May 9 2005, 07:27 PM
Member Group: Members Posts: 254 Joined: 14-November 04 From: Atascadero, CA Member No.: 3,117 Region Association: None |
That car looks insane. How much (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif)
What's in it? LukeD |
cametal |
May 9 2005, 09:16 PM
autox'n Group: Members Posts: 76 Joined: 28-July 03 From: Oklahoma City, OK. Member No.: 960 |
You may also want to check the case thickness before you drill.
Be sure whatever size tap your using can cut enough threads to seal well. Might be better to change your throttle linkage. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
iamchappy |
May 9 2005, 09:38 PM
Here are some new pictures of my fittings hope it helps.
iamchappy |
May 9 2005, 09:39 PM
2cc
iamchappy |
3cc
iamchappy |
May 9 2005, 09:40 PM
4cc
0396 |
May 10 2005, 07:41 AM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
iamchappy,
Your pictures look VERY interesting (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) |
joea9146 |
May 10 2005, 09:36 AM
iamchappy... Thanks for the Additional Pictures
Lo-Fi Version | Time is now: 29th April 2024 - 06:30 AM |
