Group Buy: rear fog light harness |
ConeDodger |
May 7 2017, 05:05 PM
Apex killer! Group: Members Posts: 23,588 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Ok, I've reached out to our own harness expert to see what he would need as far as a group buy to get a reproduction of the original harness done. The harness for these is pretty involved and goes all the way from the lamp to the switch so it isn't a super cheap thing.
We need 20 sets to make this happen and you can probably get Jeff to give you a deal on one of the other types of harnesses he makes or at least throw it in the same box and save some shipping. So, we need at least 20 sets to get the $206 per harness price. Who's in? (IMG:style_emoticons/default/piratenanner.gif) Besides sounding off here, you need to contact Jeff Bowlsby via (IMG:http://www.914world.com/bbs2/style_images/L11E/p_email.gif) with this information - quantity, name, email, and physical address (so he can quote shipping) he will get back to you with total cost. Oh, and Niklas, international shipping is not a problem. |
maf914 |
May 8 2017, 10:08 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
Is the rear fog-light controlled by the front fog-light switch? Or is a separate rear fog-light switch used?
raynekat |
May 8 2017, 01:50 PM
Advanced Member Group: Members Posts: 2,158 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Is the rear fog-light controlled by the front fog-light switch? Or is a separate rear fog-light switch used? Can do either....depends if you want the front and rear fogs to operate independently or not. I have opted to add a 2nd switch for maximum control. BTW: the factory harness which I have in my hand consists of two wires, two sleeves and 3 crimp on connectors. That's it. Very simple. |
JeffBowlsby |
May 8 2017, 06:00 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
BTW: the factory harness which I have in my hand consists of two wires, two sleeves and 3 crimp on connectors. That's it. Very simple. Looks simple alright, but don't be deceived about how easy it is to push a single wire through about 20 feet of small diameter heat shrink. And the white/green stripe wire is special order only available in 1000ft quantities... |
jkb944t |
May 9 2017, 05:53 AM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
BTW: the factory harness which I have in my hand consists of two wires, two sleeves and 3 crimp on connectors. That's it. Very simple. Looks simple alright, but don't be deceived about how easy it is to push a single wire through about 20 feet of small diameter heat shrink. And the white/green stripe wire is special order only available in 1000ft quantities... Wouldn't it be easier to run .03 mig welding wire through the heat shrink sleeve and then hook it to the wire and pull it back through the 20 feet of heat shrink sleeve? Jeff B |
Lo-Fi Version | Time is now: 17th May 2024 - 06:54 PM |
