Mallory with pertronix module, Anyone running this combo? |
jeffdon |
May 26 2017, 08:45 AM
If so, how has it worked out?
Optimusglen |
May 26 2017, 09:35 AM
Senior Member Group: Members Posts: 905 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest |
I am, it's a Mallory dual point with the points yanked and swapped with Pertronix. Non redcap.
I just got it running, the guy doing the tuning says it purrs, so here's hoping. |
jeffdon |
May 26 2017, 09:52 AM
I am, it's a Mallory dual point with the points yanked and swapped with Pertronix. Non redcap. I just got it running, the guy doing the tuning says it purrs, so here's hoping. Mine came with the optical module. I just fried another one. I have heard the pertronix is more robust. I am wondering if its an easy plug and play solution. |
MarkV |
May 26 2017, 11:41 PM
Works great, it comes mounted to a plate that replaces the entire Mallory point plate. If you are replacing a Unilite I would think it would replace the plate where the Unilite is mounted. You are going to need a rotor for a 4 cylinder YL Mallory distributor to replace the Unilite rotor....no hat with slots for the LED. Maybe the Unilite rotor can be modified.
MarkV |
May 27 2017, 12:28 AM
Do they make a kit to go from a Unilite Mallory to a Pertronix? Mine started out as a Mallory dual point and the magnetic ring indexes to the ignition point lobes. If your Mallory started out as a Unilite I would think the shaft would be smooth with no lobes and there would be no way to index the magnet.
jeffdon |
May 27 2017, 08:04 AM
Do they make a kit to go from a Unilite Mallory to a Pertronix? Mine started out as a Mallory dual point and the magnetic ring indexes to the ignition point lobes. If your Mallory started out as a Unilite I would think the shaft would be smooth with no lobes and there would be no way to index the magnet. Good "point". (IMG:style_emoticons/default/lol-2.gif) |
Lo-Fi Version | Time is now: 4th May 2024 - 07:41 PM |
