Anyone recognize these rear springs?, Very blue... |
arne |
Jun 17 2017, 02:41 PM
Serial Rescuer of old vehicles... Group: Members Posts: 738 Joined: 31-January 17 From: Eugene, Oregon Member No.: 20,799 Region Association: None |
I got a pair of these in a batch of misc. 914 parts. Or rather, we think these springs are for 914. Very blue, 1/2" wire, 14" free length, about 7 coils (allowing for the flattened ends), correct diameter for 914 at 4.25" (110mm?). Seems like they'd be rather stiff. Anyone recognize them? Need to figure out what they are before I offer them for sale.
SixerJ |
Jun 17 2017, 03:22 PM
Member Group: Members Posts: 448 Joined: 24-June 13 From: UK Member No.: 16,042 Region Association: England |
arne |
Jun 17 2017, 03:37 PM
Those are similar color, but lots more coils and thinner wire.
ConeDodger |
Jun 17 2017, 04:11 PM
Apex killer! Group: Members Posts: 23,591 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Look like Weltmeister 140# springs... Mine had the number 140 on the outside of the spring coil.
arne |
Jun 17 2017, 05:37 PM
I looked again at both springs carefully, Rob. No marking at all. Drat! The Weltmeister 100 lb. I put on the rear of the car are black and well marked, both brand and rate.
The 100 lb. springs are 11mm wire, these blue are a full 1/2" (12.7mm). so probably at least 140 lb., perhaps more. Would be nice to know for sure though. |
TheCabinetmaker |
Jun 17 2017, 06:39 PM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
A 140 lb spring will compress 1" when 140 lbs is applied.
r_towle |
Jun 17 2017, 09:33 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
They can be tested
KevinW |
Jun 18 2017, 06:10 AM
Newbie Group: Members Posts: 42 Joined: 25-May 15 From: Winona, Minnesota Member No.: 18,761 Region Association: Upper MidWest |
I have a similar set, mine are black with a gray stripe.
14 1/8" long and 7/16" wire. |
Optimusglen |
Jun 18 2017, 11:10 AM
Senior Member Group: Members Posts: 909 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest |
You can calculate the spring rate pretty easilly. you need the free length, , number of sprung coils, wire diameter, coil diameter, and end style. You can guess on material since all of the steels are pretty close.
Http://www.thespringstore.com/spring-calcu...calculator.html |
Chris914n6 |
Jun 18 2017, 12:38 PM
Jackstands are my life. Group: Members Posts: 3,320 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Look like the 200lb springs RH was selling back in my day.
arne |
Jun 18 2017, 01:00 PM
Look like the 200lb springs RH was selling back in my day. As a 914 noob, who is RH? |
maf914 |
Jun 18 2017, 05:45 PM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
As a 914 noob, who is RH? I really don't know, but RH might be Renegade Hybrids who do V-8 conversions and parts. Just a guess. (IMG:style_emoticons/default/idea.gif) |
TheCabinetmaker |
Jun 19 2017, 12:09 PM
Restoration design
Lo-Fi Version | Time is now: 19th May 2024 - 12:11 AM |
