what is the best way to remove a ball joint without the tool? |
tazz9924 |
Jul 28 2017, 04:10 PM
Senior Member Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
as the title states what is the best way to remove the ball joint from the control arm with out the proper tool?
frostyf |
Sep 15 2020, 09:37 PM
Member Group: Members Posts: 153 Joined: 27-March 14 From: VA 23455 Member No.: 17,168 Region Association: MidAtlantic Region |
I wanted to ask for some tips or advice on this to avoid any damage!
I am trying to change my ball joints (73) which have rotted (rubber is cracked) Decided to buy the tool for the ball joint nut (Sir tool 4 pronged). 1. First off I've removed the cinch bolt from the base of the shock absorber but the ball joint pin seems firmly attached inside the base of the shock absorber/strut. Can I heat that area to try and loosen it or does that risk damage to the shock/strut? 2. Is a pickle fork safe to use here, I'm concerned about damaging the control arm (not concerned about the ball jt as its going in the bin) 3. Is an impact driver best to remove the old balljoint nut (using the 4 pronged socket) or can you use a breaker bar? Same question for torquing up the new one. Wondered if people have used a thick walled ext bar on their breaker bar for more leverage? 4. Finally I've started this with the top hat and brake caliper still attached. Should I have removed these first? |
Lo-Fi Version | Time is now: 3rd May 2024 - 03:43 AM |
