what is the best way to remove a ball joint without the tool? |
tazz9924 |
Jul 28 2017, 04:10 PM
Senior Member Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
as the title states what is the best way to remove the ball joint from the control arm with out the proper tool?
914Sixer |
Jul 28 2017, 08:21 PM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Make sure you soak the nut in PB Blaster overnight. Make sure your impact is rated for more than 250lbs. Make sure the socket is on correctly, it will be at an angle, not straight up and down. Nut should spin off with a quick burst of the trigger.
Use the correct tool! |
Lo-Fi Version | Time is now: 26th April 2024 - 07:34 PM |
