> Charcoal system, Do I need it?
914 RZ-1
post Aug 20 2017, 02:27 PM
Porsche Padawan
I've just noticed the hoses from the charcoal canister to the engine have been cut (down in the front fender well). Is it necessary to replace these or can I get rid of the canister and hoses? Do I just plug the connections in the fan shroud and air intake if I do get rid of it?
Mike D.
post Aug 20 2017, 02:46 PM
OK, It runs now, and pretty good too!
Probably why you smell gasoline all the time (IMG:style_emoticons/default/biggrin.gif)
914 RZ-1
post Aug 20 2017, 05:24 PM
Porsche Padawan
After doing a bit of research it seems the canister keeps the gas smell out. So I think I will keep it. But I need to fix the lines.
Anyone got a source for the 12mm plastic line that goes along the rocker panel into the engine compartment? Couldn't find it at pelican. Could I just use fuel line?
VaccaRabite
post Aug 20 2017, 05:44 PM
En Garde!
Do you need it? No. Do you want it? Yes.
Zach
mgp4591
post Aug 20 2017, 05:49 PM
QUOTE(914 RZ-1 @ Aug 20 2017, 05:24 PM) *
Fuel lines will work just fine.
Tjmrfe
post Aug 20 2017, 06:02 PM
NON IMPEDING RATIONE COGITATIONIS
QUOTE(914 RZ-1 @ Aug 20 2017, 03:24 PM) *
Yes, I've replaced mine with fuel lines...
JeffBowlsby
post Aug 20 2017, 06:46 PM
Try McMaster Carr
post Aug 20 2017, 07:17 PM
914-6 GT in waiting
Vacuum lines
Optimusglen
post Aug 20 2017, 07:53 PM
More necessary with a fuel system that has a feed and a return like stock. If you swap to carbs and cap the return there's less fuel churn and less fumes. I deleted mine and haven't noticed a gas smell once.
914 RZ-1
post Aug 20 2017, 09:12 PM
Porsche Padawan
QUOTE(Jeff Bowlsby @ Aug 20 2017, 05:46 PM) *
Try McMaster Carr
Like this:
https://www.mcmaster.com/#standard-plastic-...tubing/=19142pq
There's a whole bunch of hose on the site. I picked fuel hose and just looked for something as close to 12mm [0.472"] ID as possible. That's either 7/16" (.4375) or 12/32" (0.468").
My FLAPS website didn't show the hose they sell by the foot. I'll have to go in. Problem is I need about 6-7 meters of this stuff, so I hope they have enough.
Anybody use the plastic tubing that can be had at Home Depot/Lowes? It's just fuel vapor (no gas); does the tubing need to be anything special, or will PVC work just fine?
post Aug 20 2017, 09:26 PM
Resident German
QUOTE(914 RZ-1 @ Aug 20 2017, 01:27 PM) *
Do you like the smell of gasoline in the morning?
(IMG:style_emoticons/default/blink.gif)
I removed mine some 12 years ago and that was one of the worst decisions i have made with that car to date.
It's on my list of things to fix ...
(IMG:style_emoticons/default/smash.gif)
pete000
post Aug 20 2017, 10:38 PM
I think the Euro spec cars didnt run them?
My wife hates the smell of old german cars so I keep mine in to reduce the fuel smell. No benefit to remove it.
GeorgeRud
post Aug 21 2017, 09:41 AM
No benefit to removing them so why not minimize the gas smell? With all the modern fuel injected cars, folks have forgotten what carbs used to smell like. Modern ethanol laced fuels also contribute more smell due to their higher vapor pressure and lower boiling points.
post Aug 21 2017, 10:56 AM
Resident German
QUOTE(GeorgeRud @ Aug 21 2017, 08:41 AM) *
I have modern fuel injection and i get *lots* of gasoline smell without the charcoal canister system.
The smell comes from the tank overflow since that is where i routed the evap hose into when i removed the canister.
Anything over 1/2 tank of gas and you feel like you're sniffing gas straight out of the nozzle.
(IMG:style_emoticons/default/icon8.gif)
post Aug 21 2017, 11:07 AM
914-6 GT in waiting
QUOTE(SirAndy @ Aug 21 2017, 12:56 PM) *
Andy - just say the word and I'll send you parts. (IMG:style_emoticons/default/beerchug.gif)
Mark Henry
post Aug 21 2017, 11:24 AM
that's what I do!
How would you run it to a rain hat weber /6, '74 conversion?
I have it plugged right now and this has got me thinking, but I'd have to relocate the canister.
post Aug 21 2017, 11:40 AM
Resident German
QUOTE(Mark Henry @ Aug 21 2017, 10:24 AM) *
All you need is pressure which you should be able to get from the fan shroud on a /6 and then route the return to one of your rain hats.
There should be enough suction (even at idle) to suck in the fumes and burn them without generating more fuel smell in the engine compartment.
I've been thinking about doing exactly that and routing the return into the K&N air filter on my FI intake.
DRPHIL914
post Aug 21 2017, 11:46 AM
Dr. Phil
I have not had fumes ever since making sure the vent lines were clear and I refilled the canister with the new activated charcoal.
Mark Henry
post Aug 21 2017, 12:56 PM
that's what I do!
QUOTE(SirAndy @ Aug 21 2017, 01:40 PM) *
Sounds easy enough,
To do list...it's always one line scratched off, two more lines added... (IMG:style_emoticons/default/huh.gif) (IMG:style_emoticons/default/rolleyes.gif)
- Lo-Fi Version Time is now: 4th March 2026 - 11:49 PM
