Been a while since I've shared any 3D model work, 2.2T 6 cyl and other Porsche content |
Optimusglen |
Aug 27 2017, 09:15 AM
Senior Member Group: Members Posts: 905 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest |
Progress on my 2.2T build for my 914 has slowed a bit due to funding. So I was able to take that effort and begin a project that I've wanted to do for months.
I'm 3D modeling the whole engine. Model work is done using Creo, the images rendered using Keyshot. Started on a few of the easier parts, well maybe not the easiest, but together they make up a large chunk of the engine and a big push of progress at the beginning helps the project move along. I'm modeling these from actual parts, on my dining room table. Which is another reason I started with these particular parts, they're already cleaned. Anyway, here's the first shot. More progress later in the week because I'll have a bit of time, but this is an open ended project. It gets work when I can. (IMG:http://www.914world.com/bbs2/uploads_offsite/c1.staticflickr.com-19709-1503846927.1.jpg) |
NeunEinVier |
Oct 11 2017, 11:25 AM
Member Group: Members Posts: 110 Joined: 24-December 15 From: In front of the smoke. Member No.: 19,488 Region Association: None |
I'm 3D modeling the whole engine. Model work is done using Creo, the images rendered using Keyshot. Started on a few of the easier parts, well maybe not the easiest, but together they make up a large chunk of the engine and a big push of progress at the beginning helps the project move along. This 3D modeling stuff boggles my mind, how can it even be done without having the original CAD files for each component? And doing it at home no less... |
Optimusglen |
Oct 11 2017, 12:20 PM
This 3D modeling stuff boggles my mind, how can it even be done without having the original CAD files for each component? And doing it at home no less... It's easier once you wrap your mind around the process. Think about modeling a square block, within the software you define where you want the block to be, typically a plane to start. Then you define how big you want the block in 2 of it's three dimensions, lets say 4 inches by 6 inches, then you define how big you want it in the third dimension, lets do 2 inches. This is called an extrude. For a cylinder, your starting shape would be a doughnut instead of a rectangle Each feature is broken down the same way, but piling these features on top of eachother makes the part more complex. Some features might be cuts instead of an extrude. Some might be revolves, where you define a center axis and a cross section and the shape is revolved around thew axis. Really complex stuff gets modeled as a set or surfaces, where you can merge and cut the surfaces, or sweep along curved edges. Now take that and multiply by infinity. Easy as cake. (IMG:style_emoticons/default/tongue.gif) |
Lo-Fi Version | Time is now: 5th May 2024 - 08:43 AM |
