914-6 2.7 Euro RS Twin Plug Project, sleeper 914 with a twin plug surprise |
davehg |
Sep 19 2017, 06:57 PM
Member Group: Members Posts: 185 Joined: 19-September 17 From: PNW Member No.: 21,443 Region Association: Pacific Northwest |
New member, long time lurker here. I'll be posting another 914-6 conversion project shortly, but posting a thanks for now for all the great info I've come across here.
I took the easy way into 914-6 ownership - I bought a completed car that was a track car whose PO had done the hard work. This car has a 3.2L engine, injected, with large riveted composite flares, and a pretty austere race-friendly interior with racing seats, roll cage, and little else - not even side windows or carpeting or panels. This car I refer to as the Outlaw - it's a middle finger to the purists and I absolutely love it. But...I wanted a clean and pretty "cars and coffee" version. There's not a ton of value restoring the Outlaw. The Outlaw's body is fine, but it is purposely built. I had bought a project from a local Porschephile who had too many nice projects (356, pre-73 911). his goal was originally to do a big Raby 4. He had stripped, prepped, and beautifully painted a really nice shell, and spent a small fortune getting the original bumpers and details correct. He had a set of mint Fuchs 14" wheels, bits and pieces from 2 interiors, and was really only missing the engine and some trim/interior bits. A deal was struck, trailer was hitched, boxes moved, and now it's my problem. The conversion wisdom here seems to be to go big - 3.0l or more. But I have a big engine car. This is intended to be just a Sunday cruiser, no track time. Plus, I have access to perfectly nice prepped 2.7L that has case guards installed, a 911s cam, and the work mostly done, for a decent price, and it would sound just swell with PMOs. So I am heading this route. I am taking my time with the Pretty Car - not going to be concours but a great looking driver with super clean details, no flares, and more along the lines of an original -6 with a bit more oomph. I'll detail the suspension bits so it looks pretty on a lift, and I need to think through the oil cooling issues - it doesn't get super hot in the PNW but for a few days a year, and if I can avoid the expense of a front mounted cooler and running lines that would be just swell. At least that's my current plan. We'll see where my budget leads. I have a good start - great primed and painted rust free shell, all the expensive body work complete, an engine lined up, and a clear vision of where I want to go. Looking forward to the collective input and experience when I get started this winter. |
davehg |
Sep 21 2017, 02:01 PM
Thanks Perry and Mikey. I am just outside of Seattle.
Here's where I am thinking about general gameplan - first by starting with a list of what I have and what I will need at various stages: 1. Get a working roller. This entails pulling the suspension bits off the body (they are just there for rolling the body). Take the 911 S front end suspension I got with the project and clean it up, same with the rears (trying to locate two rear 5 lug hubs - either aftermarket or if I can source a 911 rear). Nail down steering rack. Take those pieces and get them powder-coated/plated. Probably will stick with stock shocks/struts and not pursue coil overs. Clean and powdercoat fuel tank. 2. Simultaneously, work on getting the 2.7L ready. It needs top end work, and ditch the CIS for a set of PMOs tweaked to match the engine (it has an S cam). 3. Figure out the oil cooling system. I have a 2 part Vellios tank I got off ebay, but thinking to buck up for the Pelican tank or something similar. I need a complete system - lines, fittings, etc. Will hold off on a front oil cooler - for the drives and climate in the PNW, not sure it's worth the extra $$$. 4. Assemble the roller - suspension - steering - brake - pedal bits. Basically, a true roller. Install power train and connect fuel/oil/brake lines. Finish electrical wiring. Essentially, get a running roller with only interior to finish. 5. Finish interior/trim/glass/rubber. I'll need a new dash top, reupholster stock seats (tartan plaid inserts maybe!), and finish interior with RS style interior - new RS door panels, grey carpet, many misc. bits. Glass and trim finished too. I think I need lots of rubber. 6. Watch as this project sucks all my free cash, but smile when it's done! |
Dave_Darling |
Sep 22 2017, 02:20 PM
914 Idiot Group: Members Posts: 14,986 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
(trying to locate two rear 5 lug hubs - either aftermarket or if I can source a 911 rear). You will need to do some finagling with the drive axles if you use 911 hubs. The spline count is different on the stub axles than on the 914. Ping the folks at PMB Performance. They should have all the stuff you need. Most especially all of your brake needs. --DD |
Lo-Fi Version | Time is now: 17th May 2024 - 10:40 PM |
