914-6 2.7 Euro RS Twin Plug Project, sleeper 914 with a twin plug surprise |
davehg |
Sep 19 2017, 06:57 PM
Member Group: Members Posts: 185 Joined: 19-September 17 From: PNW Member No.: 21,443 Region Association: Pacific Northwest |
New member, long time lurker here. I'll be posting another 914-6 conversion project shortly, but posting a thanks for now for all the great info I've come across here.
I took the easy way into 914-6 ownership - I bought a completed car that was a track car whose PO had done the hard work. This car has a 3.2L engine, injected, with large riveted composite flares, and a pretty austere race-friendly interior with racing seats, roll cage, and little else - not even side windows or carpeting or panels. This car I refer to as the Outlaw - it's a middle finger to the purists and I absolutely love it. But...I wanted a clean and pretty "cars and coffee" version. There's not a ton of value restoring the Outlaw. The Outlaw's body is fine, but it is purposely built. I had bought a project from a local Porschephile who had too many nice projects (356, pre-73 911). his goal was originally to do a big Raby 4. He had stripped, prepped, and beautifully painted a really nice shell, and spent a small fortune getting the original bumpers and details correct. He had a set of mint Fuchs 14" wheels, bits and pieces from 2 interiors, and was really only missing the engine and some trim/interior bits. A deal was struck, trailer was hitched, boxes moved, and now it's my problem. The conversion wisdom here seems to be to go big - 3.0l or more. But I have a big engine car. This is intended to be just a Sunday cruiser, no track time. Plus, I have access to perfectly nice prepped 2.7L that has case guards installed, a 911s cam, and the work mostly done, for a decent price, and it would sound just swell with PMOs. So I am heading this route. I am taking my time with the Pretty Car - not going to be concours but a great looking driver with super clean details, no flares, and more along the lines of an original -6 with a bit more oomph. I'll detail the suspension bits so it looks pretty on a lift, and I need to think through the oil cooling issues - it doesn't get super hot in the PNW but for a few days a year, and if I can avoid the expense of a front mounted cooler and running lines that would be just swell. At least that's my current plan. We'll see where my budget leads. I have a good start - great primed and painted rust free shell, all the expensive body work complete, an engine lined up, and a clear vision of where I want to go. Looking forward to the collective input and experience when I get started this winter. |
mepstein |
Jan 19 2018, 07:37 AM
914-6 GT in waiting Group: Members Posts: 19,283 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
The Engleman had an issue with shorting to the chassis. Just make sure that is worked out before you power up the car.
davehg |
Jan 19 2018, 12:48 PM
The Engleman had an issue with shorting to the chassis. Just make sure that is worked out before you power up the car. Hmmm, thanks for this info. Was there a specific fix? I did find the following discussion on another old thread: "The "Y" splitters can touch the metal fuse panel frame when bolted in place. Mine were very tight after the Engman/JWest upgrade. I had to loosen the factory wrap on the harness to allow for extra wire movement above the panel. Shrink tubing on the bare brass bits will help also. NOTE: The constant power to the fuse panel and ignition switch is UN-FUSED at the battery. If you short the large red wires to ground/earth, the wire will melt everything from the battery to the short. It may cause a fire. Add 4 inline fuses at the battery 20 amps will due for each. Now that you have modified the electrical system with the new fuse panel, this is an important issue for you. 40 years ago when the 914 rolled off the assembly line, the unfused wires were not a big deal. 40 years later, old insulation, previous owners, radio installs, hacked wiring, etc... Your electrical system is at risk." |
Lo-Fi Version | Time is now: 23rd May 2024 - 04:15 PM |
