Got my Sunpro Digital Engine Analyzer CP7676, Sooo easy! Must Have! |
yarin |
May 25 2005, 08:03 PM
'14-X'in FOOL Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
'72 914-4 Webers 40s, stock motor
I got my meter off ebay for $24, hooked it up right away and BAM. My dwell was set to 46 degrees after gaping it with a feeler gauge. So I nudged it a bit and BAM... 49 degrees. pretty damn good. RPM works like a charm as well. I'm thinking about setting up a temporary mount inside the car hardwired for voltage, rpm and dwell. I'm taking this piece of crap Craftsman Engine Analyzer back to Sears, what a waste of 50 bucks for an analog meter. Then I busted out the timing light with advance, held at 3k rpm and adjusted the distributor to line up with TDC. I briefly caught another mark, but the mark that i lined up with is immediately to the right of the large fin on the fan. Is this correct? I'll take it for a spin tommorow and see how it runs. Sounds much better than before though. After that i will adjust the valves, one of the cylinders keeps backfiring through the intake. Hopefully its a valve clearance issue. If i'm still having problems then i'm going to order a set of those carb flow meters and learn to tune carbs. This is all on my crappy engine. I want to get some experience on these Type IVs before i drop in my higher power motor. Is my sequence of tuning correct? 1) Dwell 2) Timing Advance 3) Valves 4) Carbs |
TimT |
May 25 2005, 08:26 PM
valves first
yarin |
May 26 2005, 10:19 AM
mistro |
May 26 2005, 05:11 PM
Member Group: Members Posts: 148 Joined: 12-March 04 From: Highland Park, IL Member No.: 1,786 Region Association: None |
yarin |
May 26 2005, 06:18 PM
Sorry.. this is the item i got:
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...item=4550252741 I'm sure the other one will work just fine though. Mine is new in box, works like a charm. RPM is nice to have, but its a really slow refresh rate. I expected that though. good luck! |
MecGen |
May 26 2005, 07:06 PM
8 Easy Steps Group: Members Posts: 848 Joined: 8-January 05 From: Laval, Canada Member No.: 3,421 |
Hi
A backfire thru the carb is usually a "lean" condition. try to hear what side is farting, start there, or your carbs might not be jetted right. Small backfires, I had also, got it 99% right by playing with jets. Good luck with it Later Joe (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
Lo-Fi Version | Time is now: 8th May 2024 - 07:27 PM |
