> Turn signals - lights up but don't blink, where do I start?
potomacmidget
post Nov 12 2017, 05:34 PM
I gotta have more cowbell....
Dear All,
Took my car out for drive post clutch replacement (due to seized throwout bearing) and car shifted great (thanks again John!).
But during short drive noted that turn signals don't "blink" - they illuminate and the indicators light up on the speedometer - but not clicking sound and not blinking? Would this be a relay issue? Or a ground issue? Checked on fuses and they looked good, loosened them and repositioned in case I had some resistance from corrosion, no changed. Any advice appreciated.
Best,
Reg
oakdalecurtis
post Nov 12 2017, 05:49 PM
Oakdalecurtis
It’s your relay.
potomacmidget
post Nov 12 2017, 08:15 PM
QUOTE(oakdalecurtis @ Nov 12 2017, 06:49 PM) *
It’s your relay.
Thanks - but which relay exactly? Not the headlights, and not the ones on the board in the engine compartment? a relay on the fuse panel?
troth
post Nov 12 2017, 08:20 PM
QUOTE(potomacmidget @ Nov 12 2017, 09:15 PM) *
It’s your relay.
On my 1975 car it's the boxy, square relay on the fuse panel. Not sure if it's the same for your car.
(IMG:http://www.914world.com/bbs2/uploads_offsite/bowlsby.net-20305-1510539740.1.jpg)
oakdalecurtis
post Nov 12 2017, 08:27 PM
Oakdalecurtis
If it’s not like the diagram, just remove relays from the board under the dash one at a time until signals go off, Bingo!
potomacmidget
post Nov 13 2017, 05:21 PM
QUOTE(oakdalecurtis @ Nov 12 2017, 09:27 PM) *
Thanks, will give it a shot.
Best,
Reg
North Coast Jim
post Nov 13 2017, 05:36 PM
Just went through this myself on a 74 2L. My fuse/relay board is the same as troth previous post. Bought new relay, my blinkers worked outside the car but no dash indicator, from the local FLAPS. 22 big ones and I had a dash blinker. The original flasher had 2 internal circuits one for the dash blinker and the other for the lights outside of the car. My dash circuit failed sounds like your external light circuit failed. The new relay has only one circuit, better in my mind.
tmc914
post Nov 13 2017, 07:16 PM
When my blinkers were acting up it was two issues. First there was a bit of corrosion on one lamp, easy fix. Then I also had to change the relay. Found the relay by turning on the emergency flashers and listening for the clicking sound. The relay was tucked up under the steering column. It looked brand new. Changed it out with a different brand and all is working okay now.
altitude411
post Nov 13 2017, 08:08 PM
I drove my 6 into a tree
(IMG:style_emoticons/default/confused24.gif) easy fix... (IMG:style_emoticons/default/biggrin.gif)
potomacmidget
post Nov 21 2017, 08:45 PM
QUOTE(altitude411 @ Nov 13 2017, 09:08 PM) *
This stuff rocks! Was kind of expensive though......
I still need to pull the fuse panel down...
potomacmidget
post Nov 22 2017, 07:20 PM
QUOTE(potomacmidget @ Nov 21 2017, 09:45 PM) *
Hi All - it was the relay tucked up behind the dashboard. It appeared to be stuck. I pulled it out, put power to it and it clicked, reinstalled and it now works (for now). Thanks again for the help.
Reg
- Lo-Fi Version Time is now: 9th July 2025 - 08:27 AM
