Show me your front oil cooler shrouding, and your front cooler install pics |
Aaron Cox |
May 28 2005, 09:27 PM
Show one, show all! show me your front cooler pics!
thx fellers AA |
Series9 |
May 28 2005, 09:29 PM
I think you've seen it:
campbellcj |
May 28 2005, 11:43 PM
I can't Re Member Group: Members Posts: 4,543 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
Here's mine -- extreme overkill, but I could run summer desert enduros without worrying if I ever got to that point. So far I have never seen over 200°F on the gauge even in half hour track sessions in 100+ ambient temps.
The cooler is a giant MazdaSpeed Motorsports unit, fully shrouded with a 32" x 6" intake and exhaust thru the trunk floor. Troutman thermostat, AN-12 lines, Mobil 1 15W-50, factory tank. I usually tape-off most of the intake grille when it's not blazing hot out. Attached image(s) |
racerbvd |
Feb 15 2006, 04:50 PM
Advanced Member Group: Members Posts: 2,368 Joined: 3-February 03 From: Sunny FL. Member No.: 226 Region Association: None |
How about a 914-6GT styled one?? I need plans for my conversion
brokenmoped |
Feb 15 2006, 06:36 PM
Member Group: Members Posts: 143 Joined: 27-May 05 From: Mission Viejo, CA Member No.: 4,152 |
Here's the home depot approach...
(IMG:http://i48.photobucket.com/albums/f215/brokenmoped/109_0964.jpg) |
Allan |
Feb 15 2006, 06:38 PM
[QUOTE=brokenmoped,Feb 15 2006, 04:36 PM] Here's the home depot approach...
Trekkor help you with that? (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
Elliot_Cannon |
Feb 15 2006, 06:40 PM
Senior Member Group: Retired Members Posts: 1,922 Joined: 26-March 03 From: Orange County Ca Member No.: 480 Region Association: None |
I like the Home Depot approach. Where does the air exit? Got a wider picture?
Elliot |
brokenmoped |
Feb 15 2006, 06:58 PM
Aimed right at the rotor...
(IMG:http://i48.photobucket.com/albums/f215/brokenmoped/109_0963.jpg) |
Wild 6 |
Feb 15 2006, 07:12 PM
See you at the next autocross. Group: Members Posts: 212 Joined: 16-November 04 From: Phoenix, AZ Member No.: 3,128 |
This is what I did with my old 914. Venting through the wheel wells really worked better than the floor pan. I learned that lesson the hard way.
(IMG:http://schermuly.com/914_Front_Trunk_Lg.jpg) |
Van914 |
Feb 15 2006, 07:27 PM
Van914 Group: Members Posts: 698 Joined: 5-January 03 From: Cincinnati, Ohio Member No.: 90 Region Association: Upper MidWest |
Chris C.
Iwould like to know more about the Madzaspeed oil cooler. Thanks van914 |
Trekkor |
Feb 15 2006, 10:26 PM
That made me laugh. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Mine- KT Attached image(s) |
Marv's3.6six |
Feb 16 2006, 12:08 AM
Actual member 7" Group: Members Posts: 695 Joined: 22-November 04 From: Huntington Beach, Ca. Member No.: 3,165 Region Association: Southern California |
914-6GT styled one, in CF
Marv's3.6six |
Feb 16 2006, 12:12 AM
And cooler install, hand fab bracket on rubber isolator mounts.
RON S. |
Feb 16 2006, 05:57 AM
9140430841, FINALLY RUNNING Group: Members Posts: 1,211 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
Mine is standard fare.
Mazda OC,-16 lines to & from,Canton oil filter on the outlet side,3 cooling fans on the backside,ducted thru the floor. Ron Attached thumbnail(s) |
RON S. |
Feb 16 2006, 05:59 AM
Cooler itself I've massively re-worked.
I made the end tak removable so as to adjust the baffle-ing and to facilitate cleaning. Attached image(s) |
RON S. |
Feb 16 2006, 06:05 AM
Backside,
I boxed the area under the oc,and also under the floor pan along the 2 ribs that run front to back under the front floor pan. You can't believe how structurally stiff the front pan area has now become with those 2 mods. Attached image(s) |
RON S. |
Feb 16 2006, 06:10 AM
Bottom side.
I programmed a piece from 16GA. steel to effectively box the area. Basically it turned those stiffening ribs into tubes which are stronger. Bear in mind these are old pics from a couple years back. Ron Attached image(s) |
TimT |
Feb 16 2006, 09:22 AM
brant |
Feb 16 2006, 10:14 AM
914 Wizard Group: Members Posts: 11,618 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I've got to do it:
brant |
and exit:
Lo-Fi Version | Time is now: 4th May 2024 - 12:23 AM |
