Correct Install of Basket Weave on Glove Box |
Mike Fitton |
Jan 1 2018, 04:00 PM
Senior Member Group: Members Posts: 609 Joined: 13-May 11 From: Chicago Area Member No.: 13,069 Region Association: Upper MidWest |
What is the correct way to install the dash material on the bottom edge of the glove box door? Wrap around the face plate on 2 sides and bottom or does the bottom edge get wrap around to the inside of the door?
cal44 |
Jan 1 2018, 04:07 PM
Member Group: Members Posts: 165 Joined: 8-October 09 From: Encinitas, Ca. Member No.: 10,910 Region Association: Southwest Region |
Right or wrong, I wrapped the bottom last week on a glove box door.
I don't like leaving loose ends. |
Rob-O |
Jan 4 2018, 12:27 PM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Inside of the door. Top edge is just flush with the metal panel that the vinyl adheres to. Sides are tucked under the metal panel. Going off memory on the sides, so not 100% positive about that. But top and bottom are accurate.
defianty |
Jan 4 2018, 01:34 PM
Senior Member Group: Members Posts: 659 Joined: 9-August 06 From: Essex, UK Member No.: 6,621 Region Association: None |
GeorgeRud |
Jan 5 2018, 09:19 AM
I seem to remember you’ve got it correct as the edges are hidden with them wrapped (except for the top edge of the vinyl).
drem914 |
Mar 21 2019, 07:18 PM
Senior Member Group: Members Posts: 1,030 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California |
How does the door get removed?
bbrock |
Mar 21 2019, 07:40 PM
Sides are tucked under the metal panel. I'm sure that's correct. Only did mine a few months ago. (IMG:style_emoticons/default/agree.gif) Did mine recently too and paid very close attention to how it was originally attached. Exactly like you describe, no loose edges. |
bbrock |
Mar 21 2019, 07:44 PM
How does the door get removed? Detach the springs on the outside of the glove box on each side (that's the fun part), then from inside the box, unscrew the two chromed pivot bolts using a nickle or penny. I cheated on the springs on mine and did it with the whole dash frame out of the car. |
76-914 |
Mar 22 2019, 06:31 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,505 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
That panel will remove then you can easily wrap those 3 sides around. It is attached by a foam piece that has adhesive on both sides. It will tear but don't worry. The wrap around is a thin strip so it helps if you can compress those areas while the glue sets. Then reattach the covered metal plate to the glove box door with some silicone. (IMG:style_emoticons/default/beerchug.gif)
porschetub |
Mar 22 2019, 09:26 PM
Advanced Member Group: Members Posts: 4,702 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
don't have a clue on this mine is pretty sad ,have the material but not sure myself (IMG:style_emoticons/default/confused24.gif)
IronHillRestorations |
Mar 23 2019, 08:15 AM
I. I. R. C. Group: Members Posts: 6,721 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Tuck all the edges. Make sure all the old glue is removed before you put new on, or it won't stick. Well it will stick, until it gets nice and hot in the car and then it will start coming off
dr914@autoatlanta.com |
Mar 23 2019, 08:48 AM
914 Guru Group: Members Posts: 7,872 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
bbrock |
Mar 23 2019, 11:16 AM
You can also use double-sided tape to reattach the metal panel. The foam referenced earlier was double-sided foam tape. You can get something close, if not exactly like it on ebay but I just used thin, but heavy duty carpet tape. Worked great and no clamping or waiting for adhesive to set.
Lo-Fi Version | Time is now: 25th May 2024 - 10:08 AM |
