SS Exhasut Nut Update, Installed and Took Pictures |
914Sixer |
Feb 12 2018, 07:05 PM
914 Guru Group: Members Posts: 8,872 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
It warmed up enough today to go the the warehouse and try these out. I like the way they fit up and that the heads are 12mm. Factory nut are 13mm head. I was able to install them using a 12mm wobbel socket. The SS nut covers the entire flange of the SS heat exchangers.
Attached image(s) |
UROpartsman |
Feb 13 2018, 12:57 PM
Member Group: Members Posts: 291 Joined: 22-October 15 From: Simi Valley, CA Member No.: 19,288 Region Association: None |
Be sure to use plenty of anti-seize whenever using a stainless nut on a stainless stud or bolt, especially in a heated application. Stainless is kind of "grabby" and the threads can permanently lock together (called "galling"). In this application that would just result in the stud coming out with the nut, so not a big deal other than your nut and stud becoming a bolt.
Lo-Fi Version | Time is now: 1st May 2024 - 09:36 AM |
