SS Exhasut Nut Update, Installed and Took Pictures |
914Sixer |
Feb 12 2018, 07:05 PM
914 Guru Group: Members Posts: 8,883 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
It warmed up enough today to go the the warehouse and try these out. I like the way they fit up and that the heads are 12mm. Factory nut are 13mm head. I was able to install them using a 12mm wobbel socket. The SS nut covers the entire flange of the SS heat exchangers.
Attached image(s) |
Optimusglen |
Feb 15 2018, 12:39 PM
Senior Member Group: Members Posts: 909 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest |
I'd be very concerned about galling of the threads, better hope you never have to remove those unless you went nuts with anti seize. Even if you did, I'd be a little worried.
UROpartsman |
Feb 15 2018, 04:05 PM
Member Group: Members Posts: 291 Joined: 22-October 15 From: Simi Valley, CA Member No.: 19,288 Region Association: None |
I'd be very concerned about galling of the threads, better hope you never have to remove those unless you went nuts with anti seize. Even if you did, I'd be a little worried. ^X2. Also, check and see if common stainless studs are strong enough to handle the thermal expansion and contraction, they're just a bit stronger than grade 2 hardware, which is why you never see stainless used for suspension parts. Thermal properties are another consideration, will stainless nuts on stainless studs stay tight when heat cycled? Stainless transmits heat very poorly, which is why it warps so bad when it's welded (unless done properly by a knowledgeable welder) and why it burns up drill bits (the heat remains at the point of the drill bit and anneals its cutting edges). If you need a metal that acts as an insulator (such as heat shields), stainless is a great choice. |
Lo-Fi Version | Time is now: 19th May 2024 - 10:53 AM |
