considering replacing the backpad with carpet?Update Completed wanted to share pics, backpad replace |
jrblackbox |
Feb 13 2018, 01:08 PM
Member Group: Members Posts: 285 Joined: 8-September 15 From: Easton, CT Member No.: 19,140 Region Association: None |
Updated -I am thinking of removing the standard backpad. Anyway, I have a couple of questions. What should I cover the firewall with, perlon or carpet? Pros and cons of either? I would imagine that the sound insulator would need to come out and then glue the perlon/carpet to the bare metal? Is there anything I can do to reduce the additional noise? where can I relocate the backpad light? Any help and or suggestions appreciated, got any pics of yours post them please! TIA
Completed changing the backpad to perlon, wanted to share a couple pics. |
jrblackbox |
Feb 23 2018, 07:50 AM
Ok, there is dynamat on the firewall, would I be better off putting the OEM pad over the dynamat and then applying the perlon to the pad? Or is that overkill? My thinking is that more is better and it might be a cleaner install? what do you think?
Mowog4 |
Feb 23 2018, 08:40 AM
Member Group: Members Posts: 291 Joined: 2-November 15 From: Mesa AZ Member No.: 19,325 Region Association: None |
Ok, there is dynamat on the firewall, would I be better off putting the OEM pad over the dynamat and then applying the perlon to the pad? Or is that overkill? My thinking is that more is better and it might be a cleaner install? what do you think? I think it is overkill. The other challenge I have is I am not using stock seats, I am 6’2’ so this created a lot more room. |
Lo-Fi Version | Time is now: 19th May 2024 - 03:25 AM |
