considering replacing the backpad with carpet?Update Completed wanted to share pics, backpad replace |
jrblackbox |
Feb 13 2018, 01:08 PM
Member Group: Members Posts: 285 Joined: 8-September 15 From: Easton, CT Member No.: 19,140 Region Association: None |
Updated -I am thinking of removing the standard backpad. Anyway, I have a couple of questions. What should I cover the firewall with, perlon or carpet? Pros and cons of either? I would imagine that the sound insulator would need to come out and then glue the perlon/carpet to the bare metal? Is there anything I can do to reduce the additional noise? where can I relocate the backpad light? Any help and or suggestions appreciated, got any pics of yours post them please! TIA
Completed changing the backpad to perlon, wanted to share a couple pics. |
bajafreaks |
Jun 28 2023, 05:09 PM
Member Group: Members Posts: 73 Joined: 7-February 14 From: Gardnerville, Nevada Member No.: 16,969 Region Association: Northern California |
Digging up this older thread.
No one has mentioned if there was a difference in engine /cabin noise going this route. Dynamat and perlon is the noise level comparable to stock padding etc.? |
bkrantz |
Jun 28 2023, 08:35 PM
914 Guru Group: Members Posts: 7,753 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Digging up this older thread. No one has mentioned if there was a difference in engine /cabin noise going this route. Dynamat and perlon is the noise level comparable to stock padding etc.? I used Dynamat plus a layer of foam Dynaliner under perlon on the inside, and then replaced the stock pad on the engine side with a foil-foam sandwich. It's not "quiet" but not at all loud. Most of what I hear (with the top on) comes through the rear window glass. |
Lo-Fi Version | Time is now: 7th May 2024 - 07:41 AM |
