GB for throttle cable improved $24 will be $32 after (pics post 153), These are on 6.19.19 Will honor GB price but after will be more |
Mikey914 |
Feb 27 2018, 10:47 PM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We are looking at making an improved version of the throttle cable utilizing a thicker cable. We will be using the architectural cable we use in other applications. There has been some issue with fatigue on some of the cables currently on the market.
If there's enough interest we can easily make these with this more rugged cable. Who's in? |
Mikey914 |
Feb 28 2018, 07:51 AM
For the 6 the routing will have to be determined. Since I don't have one. we will document.
The cable itself is 1/8" It can be lubricated, but will run on an internally lined sheath. I need to do some research as to the best lubrication for the materials involved, but will ship pre lubricated, and if it's the lubrication I think I can use should not require any additional maintenance applications. |
mb911 |
Feb 28 2018, 08:15 AM
914 Guru Group: Members Posts: 6,852 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
For the 6 the routing will have to be determined. Since I don't have one. we will document. The cable itself is 1/8" It can be lubricated, but will run on an internally lined sheath. I need to do some research as to the best lubrication for the materials involved, but will ship pre lubricated, and if it's the lubrication I think I can use should not require any additional maintenance applications. I believe there is a way with a 6 to avoid the bell crank with a longer cable like the 4.. I think Terry had made some.. I need to research that a bit.. Ultimately I would love to carry a 6 cable on my website for a complete 6 conversion kit. |
bbrock |
Feb 28 2018, 08:39 AM
For the 6 the routing will have to be determined. Since I don't have one. we will document. The cable itself is 1/8" It can be lubricated, but will run on an internally lined sheath. I need to do some research as to the best lubrication for the materials involved, but will ship pre lubricated, and if it's the lubrication I think I can use should not require any additional maintenance applications. I believe there is a way with a 6 to avoid the bell crank with a longer cable like the 4.. I think Terry had made some.. I need to research that a bit.. Ultimately I would love to carry a 6 cable on my website for a complete 6 conversion kit. They have one for a six on their web site: http://www.terrycable.com/Throttle-cable-f...otor_p_303.html I'm interested in one for a carbed /4 but didn't see an answer whether installation would be plug and play for the stock item - at least as it runs through the tunnel from pedal to firewall. |
Lo-Fi Version | Time is now: 18th May 2024 - 03:40 PM |
