GB for throttle cable improved $24 will be $32 after (pics post 153), These are on 6.19.19 Will honor GB price but after will be more |
Mikey914 |
Feb 27 2018, 10:47 PM
The rubber man Group: Members Posts: 12,652 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We are looking at making an improved version of the throttle cable utilizing a thicker cable. We will be using the architectural cable we use in other applications. There has been some issue with fatigue on some of the cables currently on the market.
If there's enough interest we can easily make these with this more rugged cable. Who's in? |
Andyrew |
Feb 27 2018, 11:01 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
EVERY carbed v8 conversion could use this.. The throttle cable has to be put to such a tight angle that they snap pretty often
Sadly I am drive by wire now so I cant use this... (IMG:style_emoticons/default/sad.gif) |
76-914 |
Feb 28 2018, 09:09 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
EVERY carbed v8 conversion could use this.. The throttle cable has to be put to such a tight angle that they snap pretty often Sadly I am drive by wire now so I cant use this... (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/agree.gif) And there are enough of them to make it worthwhile. A cable for Subaru conversions would be nice as well. IIRC. the cable required for the Subaru is the same as stock except the sheathing is cut 6" shorter and cable was 6" longer. (IMG:style_emoticons/default/confused24.gif) |
Mikey914 |
Feb 28 2018, 02:45 PM
EVERY carbed v8 conversion could use this.. The throttle cable has to be put to such a tight angle that they snap pretty often Sadly I am drive by wire now so I cant use this... (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/agree.gif) And there are enough of them to make it worthwhile. A cable for Subaru conversions would be nice as well. IIRC. the cable required for the Subaru is the same as stock except the sheathing is cut 6" shorter and cable was 6" longer. (IMG:style_emoticons/default/confused24.gif) This can easily be done at this point. Maybe add as an option if you want to show the routing for others. Mark |
Lo-Fi Version | Time is now: 5th May 2024 - 11:23 AM |
