GB for throttle cable improved $24 will be $32 after (pics post 153), These are on 6.19.19 Will honor GB price but after will be more |
Mikey914 |
Feb 27 2018, 10:47 PM
The rubber man Group: Members Posts: 12,652 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We are looking at making an improved version of the throttle cable utilizing a thicker cable. We will be using the architectural cable we use in other applications. There has been some issue with fatigue on some of the cables currently on the market.
If there's enough interest we can easily make these with this more rugged cable. Who's in? |
Mikey914 |
Feb 28 2018, 09:01 AM
One of my 4s is carbbed and using a stock cable. I can do 3 versions, dtock 4, a predetermined 6 conversion, and custom to customer spec. The 3rd bersion, will be more expensive if we do it in the future, but in production its easily accomidated.
bbrock |
Feb 28 2018, 09:11 AM
One of my 4s is carbbed and using a stock cable. I can do 3 versions, dtock 4, a predetermined 6 conversion, and custom to customer spec. The 3rd bersion, will be more expensive if we do it in the future, but in production its easily accomidated. Does anyone know if a longer than stock cable can be used on a carbed 4 to allow routing the cable through the stock location in the engine tin? It's been decades since I hooked up a throttle cable to carbs and don't remember how I did it, and I was less picky back then about how I did things. I'm completely ignorant about options and what a custom spec cable would look like for this application. |
michael7810 |
Mar 4 2018, 07:42 AM
Senior Member Group: Members Posts: 1,080 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
One of my 4s is carbbed and using a stock cable. I can do 3 versions, dtock 4, a predetermined 6 conversion, and custom to customer spec. The 3rd bersion, will be more expensive if we do it in the future, but in production its easily accomidated. Does anyone know if a longer than stock cable can be used on a carbed 4 to allow routing the cable through the stock location in the engine tin? It's been decades since I hooked up a throttle cable to carbs and don't remember how I did it, and I was less picky back then about how I did things. I'm completely ignorant about options and what a custom spec cable would look like for this application. I didn't like the way the stock cable fit my carb'ed car so I made a custom cable using motorcycle cable and bicycle brake cable housing. I used a cutoff bolt, center drilled for the accelerator pedal end but the carb end was just cable (not optimal but it's been working for 5+ years with several removal/reinstalls. My cable attaches to the backside of the carb by #1 cylinder and at the stock cable was just too short. It would work but the angles were severe. Now it has nice smooth arches and is buttery smooth. My custom cable is 115.5" long including the 1-1/4" bolt swedged on the end. I should have made 2 for a spare but didn't. I recently removed it and it shows no sign of wear or damage so it should be good for a while. |
Halfnelson |
Mar 4 2018, 10:26 AM
Newbie Group: Members Posts: 46 Joined: 31-July 17 From: Cornwall Member No.: 21,303 Region Association: England |
I'll take one for 1.8 standard. Do you do clutch cable as may combine for UK postage?
Cheers Chris |
Lo-Fi Version | Time is now: 5th May 2024 - 05:22 AM |
