GB for throttle cable improved $24 will be $32 after (pics post 153), These are on 6.19.19 Will honor GB price but after will be more |
Mikey914 |
Feb 27 2018, 10:47 PM
The rubber man Group: Members Posts: 12,652 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We are looking at making an improved version of the throttle cable utilizing a thicker cable. We will be using the architectural cable we use in other applications. There has been some issue with fatigue on some of the cables currently on the market.
If there's enough interest we can easily make these with this more rugged cable. Who's in? |
Olympic 914 |
Apr 10 2018, 07:43 AM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Put me down for 2.
I have had the inner sleeve on two cables crack where it exits the firewall and transitions from the metal ferrule to the black cable housing. (don't remember the brand of cable) The first time I just replaced the cable (0 miles ) the second time I reinforced the break with multiple layers of heat shrink tubing applied while holding the cable straight. Both times this happened while the engine was out. so unplugging the cable from the metal sleeve leading in to the firewall probably would have prevented this. Expensive lessons. Are these new cables reinforced in this area? Would some type of a spring prevent this from occurring again? . |
Mikey914 |
Apr 10 2018, 08:27 AM
Put me down for 2. I have had the inner sleeve on two cables crack where it exits the firewall and transitions from the metal ferrule to the black cable housing. (don't remember the brand of cable) The first time I just replaced the cable (0 miles ) the second time I reinforced the break with multiple layers of heat shrink tubing applied while holding the cable straight. Both times this happened while the engine was out. so unplugging the cable from the metal sleeve leading in to the firewall probably would have prevented this. Expensive lessons. Are these new cables reinforced in this area? Would some type of a spring prevent this from occurring again? . |
Lo-Fi Version | Time is now: 5th May 2024 - 07:01 AM |
