GB for throttle cable improved $24 will be $32 after (pics post 153), These are on 6.19.19 Will honor GB price but after will be more |
914-300Hemi |
Mar 9 2019, 03:50 PM
Senior Member Group: Members Posts: 1,356 Joined: 7-September 06 From: San Dimas, CA Member No.: 6,794 Region Association: Southern California |
Any update?
db9146 |
Mar 24 2019, 12:14 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
I'll take a nice -6 cable if these come to fruition.
bdstone914 |
Mar 24 2019, 12:42 PM
bdstone914 Group: Members Posts: 4,514 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Mikey914 |
Mar 25 2019, 08:40 AM
The rubber man Group: Members Posts: 12,646 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I'll be spending some time on these today and tomorrow if I can solve a few little problems we can begin production.
Thanks, mark |
theer |
Jun 12 2019, 08:48 AM
Senior Member Group: Members Posts: 676 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
@mikey914
Any updates? I'd be happy to do prototype testing on Grey Matter for the Porsche-Subaru version. |
Mikey914 |
Jun 12 2019, 12:53 PM
I haven't had much time lately to spend on these but have a lot invested so yes I just need to make sure these work as planned we ran into a few issues that require some modifications over the original plan.
More to follow |
Mikey914 |
Jun 18 2019, 11:43 PM
Spent more time on these today and the 1st ones will be ready next week.
Mark |
Driver174 |
Jun 18 2019, 11:59 PM
Member Group: Members Posts: 106 Joined: 2-February 17 From: Nevada Member No.: 20,806 Region Association: None |
Is there any chance I could get a longer than stock throttle cable from you? Approximately two feet longer on the engine compartment side would be nice.
Thanks, Jim |
76-914 |
Jun 19 2019, 08:14 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
If Mark doesn't produce them there is Control Cable Inc in CA that makes custom length cables. 562-949-0455. (IMG:style_emoticons/default/beerchug.gif)
Mikey914 |
Jun 19 2019, 03:49 PM
jim_hoyland |
Jun 19 2019, 04:04 PM
Get that VIN ? Group: Members Posts: 9,265 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Can I place an order at this time ?
tyfighter123 |
Jun 19 2019, 07:11 PM
Newbie Group: Members Posts: 41 Joined: 22-September 16 From: Grand Junction Member No.: 20,422 Region Association: Rocky Mountains |
Id be in for one as well if still available
Mikey914 |
Jun 19 2019, 10:24 PM
So went rounds on the design and finally think I got it right. The larder cable created a few other problems, but it is significantly larger and will be much more robust.
Attached thumbnail(s) |
Mikey914 |
Jun 19 2019, 10:29 PM
We also included more threads in the adjuster portion. In theory more adjust ability. Or at least a wider range.
Cable is about 2.5x the size of the GEMO version. We have also added a floating lubricated sleeve on the tunnel side to help keep the cable from wearing into metal. I need one person that can install and check the fit as I'm going on the road again for 4 days. I really need to check this before I open up the flood gates. So if someone wants to give me direct feedback I can help keep these moving forward. If not I can do this mid week. Anyone? Attached thumbnail(s) |
eric914 |
Jun 20 2019, 10:59 AM
Member Group: Members Posts: 381 Joined: 28-January 04 From: Waynesville OH Member No.: 1,613 Region Association: Upper MidWest |
I'll take a -6 version when they are ready:)
Driver174 |
Jun 20 2019, 05:13 PM
Is there any chance I could get a longer than stock throttle cable from you? Approximately two feet longer on the engine compartment side would be nice. Thanks, Jim Yes, Do you just want an arbitrary 24" additional length? Or do you want to call it out. Mark Thanks for the response Mark. Let me measure it tonight, and I’ll give you the dimension. Jim |
Driver174 |
Jun 20 2019, 11:41 PM
Is there any chance I could get a longer than stock throttle cable from you? Approximately two feet longer on the engine compartment side would be nice. Thanks, Jim Yes, Do you just want an arbitrary 24" additional length? Or do you want to call it out. Mark Thanks again Mark, Longer cable length would be nice, but the increased diameter of your throttle cable is not going to work with my current throttle linkage setup. Jim |
theer |
Jun 21 2019, 11:37 AM
We also included more threads in the adjuster portion. In theory more adjust ability. Or at least a wider range. Cable is about 2.5x the size of the GEMO version. We have also added a floating lubricated sleeve on the tunnel side to help keep the cable from wearing into metal. I need one person that can install and check the fit as I'm going on the road again for 4 days. I really need to check this before I open up the flood gates. So if someone wants to give me direct feedback I can help keep these moving forward. If not I can do this mid week. Anyone? Mark - I'll be your tester.. I need a Porsche pedal end and a Subaru throttle end (barrel). Let me know. Tom |
Mikey914 |
Jun 22 2019, 01:51 AM
Is there any chance I could get a longer than stock throttle cable from you? Approximately two feet longer on the engine compartment side would be nice. Thanks, Jim Yes, Do you just want an arbitrary 24" additional length? Or do you want to call it out. Mark Thanks again Mark, Longer cable length would be nice, but the increased diameter of your throttle cable is not going to work with my current throttle linkage setup. Jim I can easy make thinner. If you want to call out cable thickness. Note the throttle side is the same as stock only the cable is larger. |
Mikey914 |
Jun 22 2019, 01:53 AM
We also included more threads in the adjuster portion. In theory more adjust ability. Or at least a wider range. Cable is about 2.5x the size of the GEMO version. We have also added a floating lubricated sleeve on the tunnel side to help keep the cable from wearing into metal. I need one person that can install and check the fit as I'm going on the road again for 4 days. I really need to check this before I open up the flood gates. So if someone wants to give me direct feedback I can help keep these moving forward. If not I can do this mid week. Anyone? Mark - I'll be your tester.. I need a Porsche pedal end and a Subaru throttle end (barrel). Let me know. Tom The tester needed is for the stock configuration as it's already made up. If no takers I can do this next Mon on my 1.7. |
Lo-Fi Version | Time is now: 30th April 2024 - 11:09 AM |
