GB for throttle cable improved $24 will be $32 after (pics post 153), These are on 6.19.19 Will honor GB price but after will be more |
11tenths |
Mar 20 2018, 09:59 AM
Ve get too soon old, und too late schmart Group: Members Posts: 142 Joined: 11-October 12 From: Islip, Long Island, NY Member No.: 15,026 Region Association: North East States |
Mark- I'm in for one for my 6 conv.
Just one question... (Columbo style) Will this loop up in front of the CV joint, or possibly more smoothly bend around behind it? (IMG:style_emoticons/default/idea.gif) - Harry |
Mikey914 |
Mar 20 2018, 10:01 AM
The rubber man Group: Members Posts: 12,639 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I was planning to do a stock cable, so location would not necessarily change, but an extra inch would give it some "slack".
Mikey914 |
Mar 28 2018, 09:29 AM
Ok, this has taken longer than I had hoped, but we are looking to nail down the lengths for the custom cables as well as the V8, and Subaru.
We will need to know the length of the actual cable you want, as well as the sheath. I will PM with nonstandard requests. |
jkb944t |
Mar 28 2018, 10:30 AM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
I am in for the -6 version.
Jeff B |
theer |
Mar 28 2018, 01:05 PM
Senior Member Group: Members Posts: 676 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
Ok, this has taken longer than I had hoped, but we are looking to nail down the lengths for the custom cables as well as the V8, and Subaru. We will need to know the length of the actual cable you want, as well as the sheath. I will PM with nonstandard requests. PM sent. My WRX with intake manifold reversed will need the cable sheath to be 140cm long measured from the end of the stock-914 cable tube to the stock Subaru cable mounting clip. |
mb911 |
Mar 28 2018, 04:00 PM
914 Guru Group: Members Posts: 6,815 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Sorry but my car is not ready to measure what the cable lengths are.. Guess I am no help.
bbrock |
Mar 28 2018, 04:50 PM
Sorry but my car is not ready to measure what the cable lengths are.. Guess I am no help. Yep, same here. Just not at a stage where I can commit to a length. (IMG:style_emoticons/default/sad.gif) |
StratPlayer |
Mar 28 2018, 07:30 PM
StratPlayer Group: Members Posts: 3,265 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Count me in for 1, late model 4, EFI.
Mikey914 |
Apr 9 2018, 08:10 PM
Made some great progress on these, however the day job is taking up some additional time in my schedule. Ill be in full production by the end of the month.
Just wanted to update the thread. This will take a little longer than planned, but should be worth the wait. Thanks, Mark |
pilothyer |
Apr 9 2018, 09:58 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
Interested in stock cable for 1.8 & 2.0 F.I. and a couple for 4 cyl. carb conversion.
davehg |
Apr 9 2018, 10:08 PM
Member Group: Members Posts: 183 Joined: 19-September 17 From: PNW Member No.: 21,443 Region Association: Pacific Northwest |
I’m in for a 6
RAX914 |
Apr 9 2018, 10:23 PM
Member Group: Members Posts: 99 Joined: 20-August 14 From: California Member No.: 17,801 Region Association: None |
I'm in for one
marksteinhilber |
Apr 9 2018, 11:07 PM
Member Group: Members Posts: 229 Joined: 18-October 12 From: Foothill Ranch, CA 92610 Member No.: 15,057 Region Association: Southern California |
I’d like one for a 1.8 L jet!
raynekat |
Apr 9 2018, 11:32 PM
Advanced Member Group: Members Posts: 2,154 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Would need one for a 914-6. Thx
porschetub |
Apr 9 2018, 11:54 PM
Hi Mark, Here's the 914-6 cable pics and info we pm'd about. over all length is : 99 1/4'' from end to end the sheathing is : 41 3/4'' from end to end the metal threaded part that mounts on the trans bracket is : 55 mm from end to end the pedal and trans threaded ends for the cup/ball socket is : 38 mm from end to end cable thickness is 2 mm and has a plastic coating on the cable itself. The pics of the 6 trans and carb manifolds are so you get an idea on how the cable mounts/runs. Let me know if you need more info. Luke But isn't that an extended pivot rod off the RH side inlet manifold,is that stock or part off the RJ conversion parts,intersested to know, (IMG:style_emoticons/default/beer.gif) |
Olympic 914 |
Apr 10 2018, 07:43 AM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Put me down for 2.
I have had the inner sleeve on two cables crack where it exits the firewall and transitions from the metal ferrule to the black cable housing. (don't remember the brand of cable) The first time I just replaced the cable (0 miles ) the second time I reinforced the break with multiple layers of heat shrink tubing applied while holding the cable straight. Both times this happened while the engine was out. so unplugging the cable from the metal sleeve leading in to the firewall probably would have prevented this. Expensive lessons. Are these new cables reinforced in this area? Would some type of a spring prevent this from occurring again? . |
Mikey914 |
Apr 10 2018, 08:25 AM
Hi Mark, Here's the 914-6 cable pics and info we pm'd about. over all length is : 99 1/4'' from end to end the sheathing is : 41 3/4'' from end to end the metal threaded part that mounts on the trans bracket is : 55 mm from end to end the pedal and trans threaded ends for the cup/ball socket is : 38 mm from end to end cable thickness is 2 mm and has a plastic coating on the cable itself. The pics of the 6 trans and carb manifolds are so you get an idea on how the cable mounts/runs. Let me know if you need more info. Luke But isn't that an extended pivot rod off the RH side inlet manifold,is that stock or part off the RJ conversion parts,intersested to know, (IMG:style_emoticons/default/beer.gif) Well the good news is as an actual manufacturer we can make adjustments. We plan to stat here and make adjustments as necessary to make the best product for the application. So we'll start here and will more than likely make adjustments based on feedback recieved. So the real answer is we will find out. |
Mikey914 |
Apr 10 2018, 08:27 AM
Put me down for 2. I have had the inner sleeve on two cables crack where it exits the firewall and transitions from the metal ferrule to the black cable housing. (don't remember the brand of cable) The first time I just replaced the cable (0 miles ) the second time I reinforced the break with multiple layers of heat shrink tubing applied while holding the cable straight. Both times this happened while the engine was out. so unplugging the cable from the metal sleeve leading in to the firewall probably would have prevented this. Expensive lessons. Are these new cables reinforced in this area? Would some type of a spring prevent this from occurring again? . |
914Sixer |
Apr 10 2018, 08:34 AM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Put me down for one.
flmont |
Apr 10 2018, 05:27 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
Ill have one also
Lo-Fi Version | Time is now: 28th April 2024 - 11:10 PM |
