Help id'ing window guide |
Kurbis |
May 8 2018, 01:40 PM
Newbie Group: Members Posts: 5 Joined: 6-October 17 From: Pittsfield NH Member No.: 21,490 Region Association: North East States |
I need help identifying a window guide for my 71's passenger side window. It is shown in diagrams under "glazing" on AA website but not identified with a part number or description. It is a guide at the lower right hand corner of the window illustrated. Any help much appreciated.
dr914@autoatlanta.com |
May 8 2018, 02:06 PM
914 Guru Group: Members Posts: 7,868 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
that part is not available without the window glass. The glue dries and it falls off usually found in the lower door cavity. If you do not have one, you MUST buy a used one, OR have Mark Whitesell make them There would be a reasonable market, but they are a combination of plastic and metal. Without it, the window will not adjust properly and rattle as well (not that there are other things that make the 70- very very very early 73 windows not rattle!
I need help identifying a window guide for my 71's passenger side window. It is shown in diagrams under "glazing" on AA website but not identified with a part number or description. It is a guide at the lower right hand corner of the window illustrated. Any help much appreciated. |
Mikey914 |
May 8 2018, 02:30 PM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Check the inside of your door. The fall off and that's where they end up. You may be able to epoxy back on.
More than willing to make, but most dont go far. |
Kurbis |
May 8 2018, 07:50 PM
Thanks for advice. I'll look inside door and if not, guess I'll be looking for used one..Thanks again
Kurbis |
May 9 2018, 03:04 AM
BeatNavy |
May 9 2018, 04:17 AM
Are you referring to this piece? I know I don't have those on my windows, and I've spent hours trying to get the windows adjusted on my '72 (mostly in vain, particularly on the driver's side).
I'd buy at least two. |
Kurbis |
May 9 2018, 03:15 PM
Are you referring to this piece? I know I don't have those on my windows, and I've spent hours trying to get the windows adjusted on my '72 (mostly in vain, particularly on the driver's side). I'd buy at least two. Yep, that's the piece. not even sure what's it's called but very, very elusive. |
914werke |
May 9 2018, 03:29 PM
"I got blisters on me fingers" Group: Members Posts: 10,083 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
How difficult would it be to update the early door to utilize the late regulators?
This is one task Ive never looked into having owned mostly mid yr cars. |
BeatNavy |
May 9 2018, 04:04 PM
How difficult would it be to update the early door to utilize the late regulators? This is one task Ive never looked into having owned mostly mid yr cars. Someone posted on that here not too long ago. http://www.914world.com/bbs2/index.php?showtopic=322769 It's something I would consider, as the early regulators can be a pain. But it doesn't look exactly plug and play. Need to decide if it's worth the trouble ... (IMG:style_emoticons/default/sad.gif) |
johnhora |
May 9 2018, 08:15 PM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
Mikey914 |
May 10 2018, 01:43 AM
I'm thinking I could make these. Really need about 30 sets at $32 a set to make this work.
BeatNavy |
May 10 2018, 04:54 AM
I'm thinking I could make these. Really need about 30 sets at $32 a set to make this work. Well now you need 29. 'Cause I'm in for one set (pair). (IMG:style_emoticons/default/smile.gif) Make an improved early window regulator button and make me REALLY happy (IMG:style_emoticons/default/beer.gif) |
May 10 2018, 07:26 AM
one would have to weld a piece into the door, then switch the complete set of guts except for the vent window
How difficult would it be to update the early door to utilize the late regulators? This is one task Ive never looked into having owned mostly mid yr cars. |
May 10 2018, 07:27 AM
76-914 |
May 10 2018, 08:23 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,504 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
How difficult would it be to update the early door to utilize the late regulators? This is one task Ive never looked into having owned mostly mid yr cars. Someone posted on that here not too long ago. http://www.914world.com/bbs2/index.php?showtopic=322769 It's something I would consider, as the early regulators can be a pain. But it doesn't look exactly plug and play. Need to decide if it's worth the trouble ... (IMG:style_emoticons/default/sad.gif) I wouldn't. Mine are modified on the 70 and looked like a PITA to do so. That and if your off 1mm on a new hole location your way off on the window seating against the seal. I spent hours getting mine corrected and it is on the extreme edge of "forced" adjustability. I think it would be easier and smarter to purchase newer doors and paint them. (IMG:style_emoticons/default/beerchug.gif) |
Kurbis |
May 10 2018, 11:46 AM
I'm thinking I could make these. Really need about 30 sets at $32 a set to make this work. Well now you need 29. 'Cause I'm in for one set (pair). (IMG:style_emoticons/default/smile.gif) Make an improved early window regulator button and make me REALLY happy (IMG:style_emoticons/default/beer.gif) Well, since I started this, I'l add my commitment for a pair as well. Thank you. |
Lo-Fi Version | Time is now: 22nd May 2024 - 03:17 AM |
