CV boot kit |
CV boot kit |
mtndawg |
May 29 2018, 10:51 AM
Member Group: Members Posts: 414 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None |
Where can I order a quality CV boot kit for both sides, boots, grease, gaskets, etc...
May 29 2018, 11:00 AM
Pmb, pelican, probably amazon and eBay.
914Sixer |
May 29 2018, 03:33 PM
Your Kit will be for a VW. To the best of my knowledge NO 4 bolt hole boots are being made. Everything is 6 hole.
Mblizzard |
May 29 2018, 07:17 PM
If you need some I have some 6 hole that have the two holes sealed with epoxy and a aluminum plate. I upgraded to the the indestructible ones (almost) used for V8 conversions.
May 29 2018, 07:30 PM
can you replace the boot on the flange? The boot sells for $3.
914Sixer |
May 30 2018, 08:32 AM
All the boots I have got do not want to stretch over flange. They pop off before you can get a clamp on them.
mgphoto |
May 30 2018, 09:26 AM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Problem is the original version of the flange which interfaces with the boot has a curved surface, the original clamps had a matching curve they are NLA.
Owners have tried everything from tie wraps to the straight edged clamps which have the correct diameter but lacking the curved edge. |
Optimusglen |
May 30 2018, 09:45 AM
Senior Member Group: Members Posts: 908 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest |
uh... I replaced all of my boots and reused the original flanges. Getting the boots over the lip of the flange takes a bit of strength but once it's stretched over it has the added advantage of retaining the boot a bit. Clamp added of course, wouldn't want to rely solely on the stretch.
I used a bike tire lever (shown in blue in the picture) to help leverage the boot on without risking puncturing the boot. I believe mine were Rein boots, purchased from FCP Euro. Price currently is a bit over $2 each. FCP also has a lifetime warranty on all parts they sell and you don't need to be a professional shop to take advantage of it. |
Mblizzard |
May 30 2018, 10:02 AM
uh... I replaced all of my boots and reused the original flanges. Getting the boots over the lip of the flange takes a bit of strength but once it's stretched over it has the added advantage of retaining the boot a bit. Clamp added of course, wouldn't want to rely solely on the stretch. I used a bike tire lever (shown in blue in the picture) to help leverage the boot on without risking puncturing the boot. I believe mine were Rein boots, purchased from FCP Euro. Price currently is a bit over $2 each. FCP also has a lifetime warranty on all parts they sell and you don't need to be a professional shop to take advantage of it. I use a heat gun to warm the boot a bit and it makes it much easier! |
Lo-Fi Version | Time is now: 16th May 2024 - 01:09 AM |
