914-6 GT oil cooler set up install and prototyping thread. |
mb911 |
Apr 18 2020, 11:50 AM
914 Guru Group: Members Posts: 6,818 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
dug |
Oct 16 2021, 09:56 AM
Member Group: Members Posts: 182 Joined: 26-December 06 From: Santa Cruz, CA Member No.: 7,382 Region Association: Northern California |
Wondering why you are doing the scavenge line like that when you already make the 914-6 style hard line the goes forward instead?
mb911 |
Oct 16 2021, 10:13 AM
Wondering why you are doing the scavenge line like that when you already make the 914-6 style hard line the goes forward instead? I just was not happy with the clearance around the oil return tubes and the heat exchangers. The OEM one was tight already so I have since abandoned those hard lines. I have some left that I would sell cheap if someone wants them. The Original early 911s also went over the bell housing. |
Luke M |
Oct 16 2021, 10:21 AM
Senior Member Group: Members Posts: 1,370 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
Wondering why you are doing the scavenge line like that when you already make the 914-6 style hard line the goes forward instead? I just was not happy with the clearance around the oil return tubes and the heat exchangers. The OEM one was tight already so I have since abandoned those hard lines. I have some left that I would sell cheap if someone wants them. The Original early 911s also went over the bell housing. Hi Ben, My brother will be looking to do the cooler lines soon. Would you happen to have a kit per say ? He would need everything from the engine to front oil cooler. He already has the oil cooler/housing kit from PMS. He needs the lines now. LMK. Thanks.. |
mb911 |
Oct 16 2021, 10:39 AM
Wondering why you are doing the scavenge line like that when you already make the 914-6 style hard line the goes forward instead? I just was not happy with the clearance around the oil return tubes and the heat exchangers. The OEM one was tight already so I have since abandoned those hard lines. I have some left that I would sell cheap if someone wants them. The Original early 911s also went over the bell housing. Hi Ben, My brother will be looking to do the cooler lines soon. Would you happen to have a kit per say ? He would need everything from the engine to front oil cooler. He already has the oil cooler/housing kit from PMS. He needs the lines now. LMK. Thanks.. I could come up with something. Do you have the cooler? |
Luke M |
Oct 16 2021, 11:00 AM
Wondering why you are doing the scavenge line like that when you already make the 914-6 style hard line the goes forward instead? I just was not happy with the clearance around the oil return tubes and the heat exchangers. The OEM one was tight already so I have since abandoned those hard lines. I have some left that I would sell cheap if someone wants them. The Original early 911s also went over the bell housing. Hi Ben, My brother will be looking to do the cooler lines soon. Would you happen to have a kit per say ? He would need everything from the engine to front oil cooler. He already has the oil cooler/housing kit from PMS. He needs the lines now. LMK. Thanks.. I could come up with something. Do you have the cooler? Have the following : Factory 914-6 engine oil cooler, 914-6 3 piece rubber lines, your SS return hard line, and Setrab front oil cooler with 12AN fittings. Also have a 12AN Mocal T-stat. |
Tdskip |
Oct 16 2021, 06:00 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
PM sent on the oil rerun lines
pete-stevers |
Oct 24 2021, 04:23 PM
saved from fire! Group: Members Posts: 2,641 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
When this is sorted Ben I would be interested for the set up as well... My last car's frunk set up looked well...kinda budget
pencap914 |
Apr 14 2022, 04:03 PM
Member Group: Members Posts: 75 Joined: 16-April 06 Member No.: 5,872 Region Association: Northern California |
Hey Ben,
Question about some of the oil lines if I decide to not go with a Porsche t-stat... What I have: -1975 2.7 engine, oem Behr cooler with a 30mm push on fitting -Your ss hard lines to a front mounted oil cooler -Your ss hard line from scavenge pump -Your Aluminum 914/6 oil tank What I plan to substitute: -Mocal male 16-AN thermostat, wherever convenient. Likely where the Porsche thermostat would mount. The Mocal units are about half the price of what I can find the Porsche ones for nowadays. *Edit: Just realized I highlighted the 12AN Mocal unit. I would be buying the 16AN unit... -What I need: -All four lines for the Mocal t-stat: 1) SS hardline - ext. oil cooler supply 2) SS hardline - ext. oil cooler return 3) t-stat to oil tank return 4) from scavenge ss hard line to t-stat -Soft line from oil tank to engine return (push on the behr oil cooler) I'm wondering if it's worth the trouble to go with the Mocal t-stat since going to/from the SS hard lines to the ext. oil cooler seems like a challenge... If popped for the OEM Porsche thermostat, would it make life easier to simply order pre-bent and pre sized oil lines? |
Apr 14 2022, 05:19 PM
914-6 GT in waiting Group: Members Posts: 19,247 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
You might want to rethink the 16 AN lines. They are really big, especially for a 2.7. Even a modified one.
Luke M |
Apr 26 2022, 01:12 PM
Hi Ben,
Any updates on this? |
mb911 |
Apr 26 2022, 03:17 PM
Lo-Fi Version | Time is now: 1st May 2024 - 10:44 AM |
