Improving tail lights |
Rusty |
Aug 11 2018, 03:56 PM
Wanted: Engine case GA003709 Group: Admin Posts: 7,941 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
Maybe (probably) this has been done in the last ten years. But I'd like to improve my rear lights.
Two things: 1. Are reasonably priced rear lenses available? I gave away a NOS set a while back... not my best decision, but not my worst. 2. I'd like to improve the lighting in general. My thoughts are that the 40+ year old reflective paint inside could use brightening. Also, LED technology has gone a long way. Do we have any lessons learned on either? thanks, Rusty |
7TPorsh |
Aug 18 2018, 05:24 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
Actually referring to this reflector. LED behind here double the light in your line of site.
bandjoey |
Aug 18 2018, 06:13 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Actually referring to this reflector. LED behind here double the light in your line of site. How little things get overlooked. LEDs on tail and stop. Adding one in the reflector box does give more visibility. I think the 3rd light up high is the best thing you can do. |
ClayPerrine |
Aug 19 2018, 07:41 AM
Life's been good to me so far..... Group: Admin Posts: 15,465 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Actually referring to this reflector. LED behind here double the light in your line of site. How little things get overlooked. LEDs on tail and stop. Adding one in the reflector box does give more visibility. I think the 3rd light up high is the best thing you can do. It is also illegal. US DOT requirements mandate a rear reflector on all cars. If you convert that to a tail light, it will no longer be a reflector. Now if you have the big Porsche reflector between the lights, then you would be legal. Don't give a cop a reason to pull you over just because you look like you were going to speed. |
7TPorsh |
Aug 19 2018, 10:18 PM
Actually referring to this reflector. LED behind here double the light in your line of site. How little things get overlooked. LEDs on tail and stop. Adding one in the reflector box does give more visibility. I think the 3rd light up high is the best thing you can do. It is also illegal. US DOT requirements mandate a rear reflector on all cars. If you convert that to a tail light, it will no longer be a reflector. Now if you have the big Porsche reflector between the lights, then you would be legal. Don't give a cop a reason to pull you over just because you look like you were going to speed. J didn't remove the reflector. It's translucent thin plastic and the light shines through at night. Lights up and reflects. |
Lo-Fi Version | Time is now: 17th May 2024 - 01:50 PM |
