oil cooler, i finished it! |
BravoHotel |
Jul 13 2003, 05:33 PM
Member Group: Members Posts: 153 Joined: 5-March 03 From: Columbus, MS Member No.: 399 |
Finished the plumbing today. I am very pleased w/ the end result. I would like to thank all those who gave input...this is a great place to hang out and learn.
Brian Attached thumbnail(s) |
BravoHotel |
Jul 13 2003, 05:34 PM
nother pic
BravoHotel |
Jul 13 2003, 05:35 PM
and another...
BravoHotel |
Jul 13 2003, 05:36 PM
last one...
rhodyguy |
Jul 13 2003, 05:50 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
what does the red line carry? i hope that bulkhead doesn't cut through it. think it needs a grommet?
kevin |
BravoHotel |
Jul 13 2003, 05:54 PM
its just a vent for the fuel cell...it carries air (IMG:style_emoticons/default/smile.gif)
seanery |
Jul 13 2003, 06:09 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,852 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
I like your line routing.
That's the ticket for the blue car! Thanks for showing us. |
BravoHotel |
Jul 13 2003, 06:20 PM
no problem...it's fun being part of the "community". The hose routing was "fairly" painless...I did it solo. The only tricky part was getting the hose to make the vertical 90deg transition up and out of the longitudnal...fairly tight radius. I was able to get it partially up the radius, then had to reach straight down from the front trunk and grab both hoses w/ some pliers. From there just tug, tug, tug. BTW, you have to fish the hose THEN put the fittings on. (IMG:style_emoticons/default/beer3.gif)
URY914 |
Jul 13 2003, 07:08 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,662 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
What is the reason for putting the cooler at the base of the windshield? Are you going to put some kind of a scope to direct air to it? I don't see how it will get any air flowing thru it.
tryan |
Jul 13 2003, 07:55 PM
Senior Member Group: Members Posts: 553 Joined: 22-January 03 From: smokey mountains gatlinburg tn Member No.: 184 |
you will have to repaint the car red. you will have the heat from hell.
i killed a vw motor in thr notchback when i glassed in an oil cooler in front of the cooling air intake. my mother is still pissed at me for fogging the house with resin fumes on thanksgiving 25 years ago. (IMG:style_emoticons/default/laugh.gif) |
madd_dogg_914 |
Jul 13 2003, 07:57 PM
Member Group: Members Posts: 478 Joined: 30-March 03 From: Vacaville, CA Member No.: 497 Region Association: Northern California |
URY914, check out this thread:
http://www.914world.com/bbs2/index.php?act...&f=2&t=3221&hl= It explains the reason for going there, the pro's and con's, and even the great Brad Roberts chimes in with a bit of insight. -Chris |
BravoHotel |
Jul 13 2003, 07:58 PM
URY, here is a link to a previous thread where my choice of locations was questioned.
http://www.914world.com/bbs2/index.php?act...=3221&hl=cooler Brad and others confirmed the validity of that location as a high pressure area. Since the stock fuel tank has been removed, the 4" dia access hole below should provide adequate space for the hot air to escape. Brian |
madd_dogg_914 |
Jul 13 2003, 08:03 PM
HAHA I beat you Bravo!!! In your own thread too!
(IMG:style_emoticons/default/tongue.gif) -Chris (Gotta get my post count up, I have been lagging lately) |
BravoHotel |
Jul 13 2003, 08:04 PM
i don't type too fast... (IMG:style_emoticons/default/confused24.gif)
URY914 |
Jul 13 2003, 08:13 PM
OK, I read the posts....
I'm still not sold on it, but any cooler in just about any location will help. It is better than mounting it to the bottom of the rear trunk-which I never understood. Be sure to share your results. Paul |
Lo-Fi Version | Time is now: 17th May 2024 - 08:57 PM |
