Side mirror, 1971 |
Side mirror, 1971 |
milwlandrover |
Aug 26 2018, 03:40 PM
Member Group: Members Posts: 149 Joined: 22-June 12 From: Greendale Wisconsin Member No.: 14,592 Region Association: Upper MidWest |
Both my '73 and '71 have crummy rubber adjustable side mirrors. what did the originals look like. I have seen pictures with round and rectangle and although both of my cars have (2) mirrors, I think the originals only had (1)
tmc914 |
Sep 7 2018, 06:32 PM
Member Group: Members Posts: 116 Joined: 24-September 17 From: Lowell, MA Member No.: 21,452 Region Association: North East States |
While on the subject of mirrors...
My passenger side is like a magnifying glass. It is almost unusable. Most mirrors say "objects may be closer..." mine should say ..."Objects appear closer...". Are there two styles of mirror? |
mepstein |
Sep 7 2018, 07:00 PM
914-6 GT in waiting Group: Members Posts: 19,272 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
While on the subject of mirrors... My passenger side is like a magnifying glass. It is almost unusable. Most mirrors say "objects may be closer..." mine should say ..."Objects appear closer...". Are there two styles of mirror? You can always replace the glass with a regular piece. |
tmc914 |
Sep 7 2018, 07:02 PM
[/quote]
You can always replace the glass with a regular piece. [/quote] Did not think of that, will have to put on my to do list. Thanks. |
mepstein |
Sep 7 2018, 07:21 PM
[quote name='tmc914' date='Sep 7 2018, 09:02 PM' post='2646589']
[/quote] You can always replace the glass with a regular piece. [/quote] Did not think of that, will have to put on my to do list. Thanks. [/quote] 914rubber has both sizes of glass. If you decide to switch it out, don't use a flat blade screwdriver to remove the plastic ring. It damages the edge of the stainless steel but do lube up the spring and nut located behind the mirror, under the base and all the pivot points on the arm. |
Lo-Fi Version | Time is now: 17th May 2024 - 09:14 PM |
