Side mirror, 1971 |
Side mirror, 1971 |
milwlandrover |
Aug 26 2018, 03:40 PM
Member Group: Members Posts: 149 Joined: 22-June 12 From: Greendale Wisconsin Member No.: 14,592 Region Association: Upper MidWest |
Both my '73 and '71 have crummy rubber adjustable side mirrors. what did the originals look like. I have seen pictures with round and rectangle and although both of my cars have (2) mirrors, I think the originals only had (1)
Mikey914 |
Sep 19 2018, 10:59 PM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yep more than happy to do so. Just need a good sample.
-Mark |
Kaeferfreund |
Nov 13 2018, 02:45 PM
Member Group: Members Posts: 122 Joined: 28-July 13 From: Germany Member No.: 16,172 Region Association: Germany |
mepstein |
Nov 13 2018, 03:08 PM
914-6 GT in waiting Group: Members Posts: 19,272 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Yep more than happy to do so. Just need a good sample. -Mark Mark, what's the current status of that reproduction? Any -good- news? I did send mikey/mark a sample of both inner and outer plastic pieces. I have plenty of outer frames since they don't seem to fall apart like the inners but they are sure a lot of work to reinstall. I wonder if they harden up over time. |
Kaeferfreund |
Nov 15 2018, 02:14 PM
Yep more than happy to do so. Just need a good sample. -Mark Mark, what's the current status of that reproduction? Any -good- news? I did send mikey/mark a sample of both inner and outer plastic pieces. I have plenty of outer frames since they don't seem to fall apart like the inners but they are sure a lot of work to reinstall. I wonder if they harden up over time. Hi! I have a follow up question to your hint : " If you decide to switch it out, don't use a flat blade screwdriver to remove the plastic ring. It damages the edge of the stainless steel (understood)....but do lube up the spring and nut located behind the mirror, under the base and all the pivot points on the arm." So if a screwdriver isn't such a good idea, how could you remove the old mirror glas without damaging neither the metal casing nor the plastic holders and the black rubber sealing ring? Any pictures here or in another discussion? |
Lo-Fi Version | Time is now: 17th May 2024 - 06:23 PM |
