Center High mounted Brake Light, any new attempts |
HansJan |
Jan 4 2019, 04:25 PM
Member Group: Members Posts: 395 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
I like the idea of the Center Brake light being as high as possible. So stick on, the underside of the targa bar, or maybe the targa rear edge. One thing to watch for, especially if you're tall, is a high stick on light may obstruct the rear view mirror. (IMG:style_emoticons/default/agree.gif) |
oakdalecurtis |
Jan 4 2019, 04:50 PM
Oakdalecurtis Group: Members Posts: 1,328 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
Well, I’m 6’4” and have no problem with my targa bar light obstructing my rear view, unless I’m looking for airplanes! (IMG:style_emoticons/default/driving.gif)
North Coast Jim |
Jan 4 2019, 04:53 PM
Member Group: Members Posts: 323 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
I have been thinking about the subject. There are only about 3 Topic Titles that pop up on a search. So I am curious if folks are doing this. I notice lots of pick-up trucks with LED strips under the tail gate. Maybe only $20 and you get blinkers (and hazards), brake lights, and reverse lights. Plus the unwanted running lights. The 1st few I saw on Amazon used a trailer wiring couple, so that would be easy. Summit Racing has one for $30 but it is 60" long. Probably too long, wonder if I could just go with 1/2 of it and skip the blinker function too? SUMMIT RACING LINK Thoughts?? Here's my solution to this issue. Bought mine at Walmart. Two to a pack. Gave the other one to my friend OLAF who installed it on his 914. |
StratPlayer |
Jan 4 2019, 06:10 PM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Added this to the car quite a while ago.
wndsrfr |
Jan 4 2019, 08:34 PM
Senior Member Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
These are easy to mount using the adhesive backing...got them at local Autozone...set the wiring to include a diode so that they work with directional signals as well as the brake lights.....
malcolm2 |
Jan 7 2019, 09:05 AM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
bandjoey |
Jan 7 2019, 11:22 AM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Stick on Autozone $20 now 5years old and still working.
Attached thumbnail(s) |
Mark Henry |
Jan 8 2019, 09:34 AM
Well, I’m 6’4” and have no problem with my targa bar light obstructing my rear view, unless I’m looking for airplanes! (IMG:style_emoticons/default/driving.gif) If the windshield has ever been replaced and the RVM was stuck on say a 1/2" higher it will be an issue. Worth checking before you install the light. |
Garland |
Jan 8 2019, 10:29 AM
Restoration Fanatic Group: Members Posts: 1,329 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
Here’s the link to my 3rd brake lamp.
3rd Brake Lamp Working on a new design, same style built into trim. Sourced this time Cadillac. Using designed lamp parts are much brighter then LED tape. |
GeorgeRud |
Jan 9 2019, 05:52 PM
Yours is the one I remembered. Nicest option I ever saw. Thanks for giving the link. I still remember that SMOG event fondly - 914s in Hell!
bbrock |
Aug 30 2020, 07:54 PM
Thought I would share the high mount third brake light I installed today. I wanted something super stealth that didn't require any cutting or drilling. I went with this flexible LED strip for motorcycles. I posted details on the install on my build thread: http://www.914world.com/bbs2/index.php?s=&...t&p=2847290 I'm very happy with the result.
(IMG:http://www.914world.com/bbs2/uploads/post-20845-1598835156.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-20845-1598835362.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-20845-1598837863.jpg) |
StratPlayer |
Aug 30 2020, 08:13 PM
Lo-Fi Version | Time is now: 31st May 2024 - 11:57 PM |
