Trickle charger questions |
bandjoey |
Jan 19 2019, 09:53 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
I've used this HF battery trickle charger for several years. Plug it in and forget it for weeks at a time. Very low and slow charge.rate. Then one day my battery, coil, and pertronics all fried at the same time while out on the road.
The shop said never use a trickle charger for more than 6 hours a day. They said no one really knows why everything went out at once and the long term use of this charger was possibly the cause. Sometimes the car sits up to 2 weeks without driving it. If I pick up a new charger do you think it should it be used for just a few hours at a time? Will a different brand be better for our cars and how long should it be connected to the battery? If I don't use a trickle charger how long do I need to drive the car to top off the battery? Attached thumbnail(s) |
mepstein |
Jan 19 2019, 10:08 PM
914-6 GT in waiting Group: Members Posts: 19,272 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I know many people who use trickle chargers on their cars, Porsche’s and other high end vehicles. Some with 20-50 cars in their collections. Never heard the issue that you had.
I use this one. Works great. Attached thumbnail(s) |
UROpartsman |
Jan 21 2019, 12:50 PM
Member Group: Members Posts: 291 Joined: 22-October 15 From: Simi Valley, CA Member No.: 19,288 Region Association: None |
I use this one. Works great. X2, Battery Tender float chargers are very good, probably the most common model for large car collections. Storing batteries on a concrete floor used to be an issue due to moisture, but that ended when the manufacturers started using plastic cases. https://northeastbattery.com/do-cement-floo...-car-batteries/ |
Lo-Fi Version | Time is now: 17th May 2024 - 06:01 PM |
