Trickle charger questions |
bandjoey |
Jan 19 2019, 09:53 PM
bandjoey Group: Members Posts: 4,923 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
I've used this HF battery trickle charger for several years. Plug it in and forget it for weeks at a time. Very low and slow charge.rate. Then one day my battery, coil, and pertronics all fried at the same time while out on the road.
The shop said never use a trickle charger for more than 6 hours a day. They said no one really knows why everything went out at once and the long term use of this charger was possibly the cause. Sometimes the car sits up to 2 weeks without driving it. If I pick up a new charger do you think it should it be used for just a few hours at a time? Will a different brand be better for our cars and how long should it be connected to the battery? If I don't use a trickle charger how long do I need to drive the car to top off the battery? Attached thumbnail(s) |
Valy |
Jan 20 2019, 02:05 AM
Senior Member Group: Members Posts: 1,671 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
The charger can't fry your coil, ignition since the key switch is off. It may damage the battery but only if the charger goes bad. And the type of damage to the battery will cause it to lose max voltage.
Lo-Fi Version | Time is now: 3rd May 2024 - 08:07 PM |
