What shade of black and does it have to be urethane for the windshield area? |
Tdskip |
Feb 7 2019, 04:51 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
I have a windshield going into one of the 1974 cars tomorrow, and I believe that I’m supposed to paint the area below the windshield in a black paint before this is done. Is there a specific product in shade that is recommended? I believe I saw urethane, but does the paint formulation matter?
Thanks! |
Larmo63 |
Feb 7 2019, 05:24 PM
Black satin.
Something quality from the local hardware store. I use the primer/paint spray cans. X - O Rust brand, works pretty well! |
ConeDodger |
Feb 7 2019, 05:38 PM
Apex killer! Group: Members Posts: 23,594 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
No! You risk cracking your new windshield if you install it with urathane. Meant to be installed with butyl tape. (IMG:style_emoticons/default/WTF.gif)
914_7T3 |
Feb 7 2019, 05:46 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,853 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
No! You risk cracking your new windshield if you install it with urathane. Meant to be installed with butyl tape. (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/agree.gif) ...and the "paint" should be butyl primer as per the below thread http://www.914world.com/bbs2/index.php?showtopic=335253 |
Larmo63 |
Feb 7 2019, 05:56 PM
I thought he meant the dash areas...... (IMG:style_emoticons/default/chair.gif)
mb911 |
914 Guru Group: Members Posts: 6,854 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
No! You risk cracking your new windshield if you install it with urathane. Meant to be installed with butyl tape. (IMG:style_emoticons/default/WTF.gif) I was wondering this same thing recently.. My last -6 had urethane on it. Getting ready to do this soon and felt the urethane just made the cowl area more robust. I actually just searched the topic and couldn't find any real data? |
Tdskip |
Feb 7 2019, 09:34 PM
Thank you for the responses, apologize about the slow follow up.
I was actually asking about the entire area, I wasn’t sure if where the window rests needs to be prepared first, I also wasn’t sure if there were areas of the dashboard that needed to be painted since they would otherwise be in accessible with the windshield in. This will be the first time I had a windshield out of one of these so I’m not quite sure about how everything comes together.. Sorry for not being more clear. |
Feb 7 2019, 10:03 PM
914-6 GT in waiting Group: Members Posts: 19,277 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
No! You risk cracking your new windshield if you install it with urathane. Meant to be installed with butyl tape. (IMG:style_emoticons/default/WTF.gif) I was wondering this same thing recently.. My last -6 had urethane on it. Getting ready to do this soon and felt the urethane just made the cowl area more robust. I actually just searched the topic and couldn't find any real data? I like butyl if only because it doesn't leave a mess like urethane if you need to replace it down the road. From what I have read, the technical reason for using butyl is there needs some give in the bond between the glass and the frame on our 914's, unlike modern cars where the urethane helps the glass become a structural element with the frame. A 911 even more so, It's glass is just held in by the rubber seal and floats within the frame. |
914werke |
Feb 7 2019, 10:24 PM
"I got blisters on me fingers" Group: Members Posts: 10,081 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/agree.gif) the Anecdotal evidence I can provide is having done a urethane install only 3 weeks after I hit an large pothole and cracked the windshield. Its Butyl only for me.
To your Q about paint, you can use "frit" paint to prep the frame before putting down the butyl rope. Also paint a flat black shadow around the Defrost vent openings. |
Tdskip |
Feb 8 2019, 10:05 AM
Thank you very much for the additional information
Tdskip |
Feb 10 2019, 05:03 PM
Tdskip |
Feb 10 2019, 05:04 PM
iankarr |
Feb 10 2019, 05:11 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
You can see the before and after primer area in post 11 of this link...
Mikey914 |
Feb 10 2019, 05:14 PM
The rubber man Group: Members Posts: 12,670 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
It actually doesn't have to be painted black. In fact the factory didn't pai t black.
I think the confusion is from the more modern urethane. It adhears to glass that has been painted with a frit. Others have went as far as to pai t the opening. If I were using the windshield chrome replacement rubber, I would use the front on the opening as without the extra 1/2" that the aluminum covers, the bead is clearly visable and it may hide some sins. If you are using the butyl chord, I would only use the self etching grit if anything at all. It was designed to be installed on th he paint. Hope that helps |
Tdskip |
Feb 12 2019, 08:39 AM
Window is in - thanks for the discussion and education.
Lo-Fi Version | Time is now: 20th May 2024 - 05:12 PM |
