GT through hood fill template? |
mb911 |
May 31 2019, 09:44 AM
914 Guru Group: Members Posts: 6,854 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Does anyone have rough dimensions for the through hood GT filler hole??
sixnotfour |
May 31 2019, 10:15 AM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
mb911 |
May 31 2019, 11:26 AM
Perfect.. This is directly inline with the center of the standard gas tank fill hole?? Just want to make sure.
sb914 |
May 31 2019, 11:38 AM
Surf Guru Group: Members Posts: 4,303 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
I think the sharpie taped to the center of the gas cap would give you a perfect measurement, maybe cut the sharpie in Half or less so it just hits the hood. Drill a pilot hole and good to go. all tanks sit a little different. Just 1/8 off would make a huge difference in alignment. (IMG:style_emoticons/default/confused24.gif)
mb911 |
May 31 2019, 03:47 PM
I hope that 1/8" wouldn't be noticeable .
Larmo63 |
May 31 2019, 05:31 PM
I put (temporary glued) a short drywall screw exactly in the middle of my gas cap and carefully shut the hood down on it to get a rough idea. It worked like a charm.
That's my drawing, but every car is a bit different. Check those measurements against your filler. |
jim_hoyland |
May 31 2019, 06:11 PM
Get that VIN ? Group: Members Posts: 9,301 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I put a short piece of soft chalk on the center of the gas cap, then gently lowered the hood to make the centering mark.
mb911 |
May 31 2019, 07:59 PM
Just measured mine based off what is drawn.. It's pretty close but it sticks 1/2" in one direction.. I will need to mount the hood and verify.
914werke |
Nov 6 2021, 08:36 PM
"I got blisters on me fingers" Group: Members Posts: 10,070 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
So how big does the hole need to be to clear a correct (100mm) "fancy" GT cap?
mlindner |
Nov 7 2021, 06:35 AM
Senior Member Group: Members Posts: 1,522 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Ben, please post pictures of your process and results. Thanks, Mark
mb911 |
Nov 7 2021, 06:45 AM
mb911 |
Nov 7 2021, 06:46 AM
mlindner |
Nov 7 2021, 06:50 AM
Old post, thanks Ben for sharing. Car looks great. Mark
Lo-Fi Version | Time is now: 18th May 2024 - 11:01 PM |
