mb911
May 31 2019, 09:44 AM
Does anyone have rough dimensions for the through hood GT filler hole??
sixnotfour
May 31 2019, 10:15 AM
mb911
May 31 2019, 11:26 AM
Perfect.. This is directly inline with the center of the standard gas tank fill hole?? Just want to make sure.
sb914
May 31 2019, 11:38 AM
I think the sharpie taped to the center of the gas cap would give you a perfect measurement, maybe cut the sharpie in Half or less so it just hits the hood. Drill a pilot hole and good to go. all tanks sit a little different. Just 1/8 off would make a huge difference in alignment.
mb911
May 31 2019, 03:47 PM
I hope that 1/8" wouldn't be noticeable .
Larmo63
May 31 2019, 05:31 PM
I put (temporary glued) a short drywall screw exactly in the middle of my gas cap and carefully shut the hood down on it to get a rough idea. It worked like a charm.
That's my drawing, but every car is a bit different.
Check those measurements against your filler.
jim_hoyland
May 31 2019, 06:11 PM
I put a short piece of soft chalk on the center of the gas cap, then gently lowered the hood to make the centering mark.
mb911
May 31 2019, 07:59 PM
Just measured mine based off what is drawn.. It's pretty close but it sticks 1/2" in one direction.. I will need to mount the hood and verify.
914werke
Nov 6 2021, 08:36 PM
So how big does the hole need to be to clear a correct (100mm) "fancy" GT cap?
mlindner
Nov 7 2021, 06:35 AM
Ben, please post pictures of your process and results. Thanks, Mark
mb911
Nov 7 2021, 06:45 AM
QUOTE(mlindner @ Nov 7 2021, 04:35 AM)
Oh man let me look for pictures. My car is in storage so not near me at the moment. The problem I discovered was I need to modify the cap fitting at some point to be slightly angled.
mb911
Nov 7 2021, 06:46 AM
mlindner
Nov 7 2021, 06:50 AM
Old post, thanks Ben for sharing. Car looks great. Mark
