> Hot weather driving, Which is better for the car?
MoveQik
post Jun 27 2005, 01:39 PM
What size wheels can I fit?
Is there a rule of thumb as to the most efficient way to drive during the summer in order to keep things as cool as possible back in the engine bay?
For example, is it better to keep the RMPs slightly higher to keep the fan pushing more air or is better to keep RPMs lower to keep the engine from generating more heat. If you can follow that logic. (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif)
TravisNeff
post Jun 27 2005, 01:47 PM
You need to drive with the engine off and have someone push you.
It's nice to hop into the car first thing in the morning and before you even start it, it is halfway to being fully warmed up
(IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
MoveQik
post Jun 27 2005, 01:49 PM
Yeah, I've noticed it never gets too hot rolling down the driveway.
TravisNeff
post Jun 27 2005, 01:55 PM
I'll soon have the kids in shape enough to push me at full sprint and even make the engine noises for me. A couple of moutain dew's and I can go for 20 miles. Cheaper than gas!
I think that if you lug the engine down you will create more heat, as well if you are revving the piss out of the engine. 2800 to 3500!?!? I really dunno.
jasons
post Jun 27 2005, 02:08 PM
Jackstand Extraordinaire
I am of the opinion you should keep the R's up so the fan spins and keeps air circulating.
redshift
post Jun 27 2005, 02:10 PM
Bless the Hell out of you!
Stop and go? NEVER going to be happy...
Idle is rough, but long periods of idle, after holding 3000 in second don't seem much better.
M
Rand
post Jun 28 2005, 04:30 PM
Cross Member
RPMs affect different things. Move more air, cool the heads... but also create more friction that heats the oil more. Yada yada.
The way to KNOW is to have good accurate gauges for oil and head temp. If something starts pushing red then you can address it.
airsix
post Jun 28 2005, 04:39 PM
I have bees in my epiglotis
My understanding is the typeIV fan cavitates at higher RPM's and actually moves LESS air when you spin it fast. Higher road speeds = higher head temps. The only way to know for sure what's going on is to use oil and head temp gauges. Hopefully the wise ones (John Larson and Jake Raby) will join this thread.
-Ben M.
ps- didn't mean to imply that others here aren't wise. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
BMartin914
post Jun 28 2005, 04:50 PM
The faster I spin that engine, the cooler the heads are. Exactly the opposite for the oil. Double-edged sword.
Never saw head temps above 300* at this past weekend's track event. Oil temps however approached 260* (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
nebreitling
post Jun 28 2005, 04:53 PM
Member Emeritus
i believe that i recall someone *wise* once saying that maximum effeciency of the fan is at 4600 rpm. but cruise at 4600 rpm and you'll be cooking your oil on most engines (w/ out an extra oil cooler).
certainly, never cruise at less than 3000 rpm. 3200-3600 seems to be a nice balance to me.
in any case, i would rather change the oil a little more often and run cooler head temps.
MoveQik
post Jun 28 2005, 05:07 PM
Thanks for the info. Sounds like good gaugees are in order. Any recommendations?
LukeD
post Jun 28 2005, 05:45 PM
I have a VDO Cht in the console and a calibrated, Numerical oil temp VD0 were the e-bralie light used to be. try Palo Alto Speedo do a Google for the website. After having them and Seeing how they react to different situations I wouldn't feel comfortable driving without them.
Luke
- Lo-Fi Version Time is now: 6th July 2025 - 09:06 AM
