What kind of Power Improvements did you see after Conversions? |
9144me2enjoy |
Aug 24 2019, 05:21 PM
Member Group: Members Posts: 310 Joined: 19-June 18 From: Oregon Member No.: 22,240 Region Association: Pacific Northwest |
There has been all kinds of engine swaps into the Base 914s (Porsche Aircooled 6 cyls-2.0L 2.2L 2.4L 2.7L 3.0L 3.2L 3.6L) along with a large range of Subaru Conversions and LS1 engines, SBC, any other conversions, along with 2056 builds etc. I’m sure a lot of people besides myself would like to see some performance specs after these conversions were completed (0-60mph 0-100mph, 1/4 mile, roll on performance) along with transmission changes and estimated cost for conversion.
Example: Upgraded to 2056cc build (Fats Performance), 125-130hp, dual 40 carbs, cam etc., headers, stock 901 side shift trans. With Rennshift Shifter, 911 suspension conversion. 0-60 6.5 seconds. 1/4 mile about 90 mph. Cost for drivetrain including trans rebuilt approx $10,000.00 in 2015. |
9144me2enjoy |
Aug 26 2019, 10:22 PM
Robarabian when you choose the EJ20T did you consider the EJ25T available in 2004 Forester? So if you had to do it again and had access and funds you would of went with a Subie 5MT or 6MT trans., Or a Boxster trans?
Robarabian |
Aug 27 2019, 10:28 PM
914 A Roo Group: Members Posts: 592 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California |
Robarabian when you choose the EJ20T did you consider the EJ25T available in 2004 Forester? So if you had to do it again and had access and funds you would of went with a Subie 5MT or 6MT trans., Or a Boxster trans? My car came built this way, but if I had to "upgrade" I would go EJ25. And I would love to see a Boxter S trans, but I am not aware of any adapter plates as of yet. I am in the process of setting up a Subie 5 speed. Have done the 4 wd to 2wd conversion, and have the MR 2 shifter and the shift linkage on the trans. I am waiting on a Clutch master cylinder adapter plate and will need to figure out the driveshafts and cables. Then it is time..... |
Jonathan Livesay |
Aug 27 2019, 10:57 PM
Senior Member Group: Members Posts: 741 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
Robarabian when you choose the EJ20T did you consider the EJ25T available in 2004 Forester? So if you had to do it again and had access and funds you would of went with a Subie 5MT or 6MT trans., Or a Boxster trans? My car came built this way, but if I had to "upgrade" I would go EJ25. And I would love to see a Boxter S trans, but I am not aware of any adapter plates as of yet. I am in the process of setting up a Subie 5 speed. Have done the 4 wd to 2wd conversion, and have the MR 2 shifter and the shift linkage on the trans. I am waiting on a Clutch master cylinder adapter plate and will need to figure out the driveshafts and cables. Then it is time..... I have a 914 Subie 2.5 turbo conversion and a stock first year (2002) WRX STI 2.0, if not for smog regs. I would switch them in a second. The 240 hp in the 3000+ lb. all wheel drive Subie is nice, a bit peaky, just need to plan ahead. The appox. 300 hp in the 2000ish lb. with 901 trans. (who needs 1st. gear anyway) 914 is a handful if you press on the gas pedal too suddenly. I dream of a smoother gentler 240 hp in the 914 and a quicker WRX. It's only a dream it would never pass smog. (IMG:style_emoticons/default/dry.gif) |
Lo-Fi Version | Time is now: 16th May 2024 - 03:58 PM |
