What kind of Power Improvements did you see after Conversions? |
9144me2enjoy |
Aug 27 2019, 05:48 PM
Member Group: Members Posts: 310 Joined: 19-June 18 From: Oregon Member No.: 22,240 Region Association: Pacific Northwest |
That’s a great 911 air cooled motor, love the redline!
iamchappy |
Aug 27 2019, 09:28 PM
More than i could of ever imagined....
Robarabian |
Aug 27 2019, 10:28 PM
914 A Roo Group: Members Posts: 591 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California |
Robarabian when you choose the EJ20T did you consider the EJ25T available in 2004 Forester? So if you had to do it again and had access and funds you would of went with a Subie 5MT or 6MT trans., Or a Boxster trans? My car came built this way, but if I had to "upgrade" I would go EJ25. And I would love to see a Boxter S trans, but I am not aware of any adapter plates as of yet. I am in the process of setting up a Subie 5 speed. Have done the 4 wd to 2wd conversion, and have the MR 2 shifter and the shift linkage on the trans. I am waiting on a Clutch master cylinder adapter plate and will need to figure out the driveshafts and cables. Then it is time..... |
9144me2enjoy |
Aug 27 2019, 10:35 PM
Chappy thats scary! Impressive build off of a 3.0L, beautiful 914.....fast
9144me2enjoy |
Aug 27 2019, 10:41 PM
Robarabian when you choose the EJ20T did you consider the EJ25T available in 2004 Forester? So if you had to do it again and had access and funds you would of went with a Subie 5MT or 6MT trans., Or a Boxster trans? My car came built this way, but if I had to "upgrade" I would go EJ25. And I would love to see a Boxter S trans, but I am not aware of any adapter plates as of yet. I am in the process of setting up a Subie 5 speed. Have done the 4 wd to 2wd conversion, and have the MR 2 shifter and the shift linkage on the trans. I am waiting on a Clutch master cylinder adapter plate and will need to figure out the driveshafts and cables. Then it is time..... Your right a upgrade to a EJ25T with a Boxster S trans would make things pretty exciting real quick! (IMG:style_emoticons/default/driving.gif) |
Jonathan Livesay |
Aug 27 2019, 10:57 PM
Senior Member Group: Members Posts: 741 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
Robarabian when you choose the EJ20T did you consider the EJ25T available in 2004 Forester? So if you had to do it again and had access and funds you would of went with a Subie 5MT or 6MT trans., Or a Boxster trans? My car came built this way, but if I had to "upgrade" I would go EJ25. And I would love to see a Boxter S trans, but I am not aware of any adapter plates as of yet. I am in the process of setting up a Subie 5 speed. Have done the 4 wd to 2wd conversion, and have the MR 2 shifter and the shift linkage on the trans. I am waiting on a Clutch master cylinder adapter plate and will need to figure out the driveshafts and cables. Then it is time..... I have a 914 Subie 2.5 turbo conversion and a stock first year (2002) WRX STI 2.0, if not for smog regs. I would switch them in a second. The 240 hp in the 3000+ lb. all wheel drive Subie is nice, a bit peaky, just need to plan ahead. The appox. 300 hp in the 2000ish lb. with 901 trans. (who needs 1st. gear anyway) 914 is a handful if you press on the gas pedal too suddenly. I dream of a smoother gentler 240 hp in the 914 and a quicker WRX. It's only a dream it would never pass smog. (IMG:style_emoticons/default/dry.gif) |
9144me2enjoy |
Aug 28 2019, 08:58 AM
Great comparison on the 2.5 914 and the 2.0 WRX STI. I think 200-250hp mark on the 914 is about right! Thanks
thelogo |
Aug 28 2019, 02:27 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
pploco |
Aug 28 2019, 02:54 PM
Chief Toilet Flusher Group: Members Posts: 105 Joined: 15-June 18 From: boise, idaho Member No.: 22,225 Region Association: Rocky Mountains |
QUOTE Sounds like a bit much for narrow body Over 175 horse . should be flared ...5lug... Sc suspension Big tires/brakes ...etc (IMG:style_emoticons/default/idea.gif) That's an awfully specific number - what do you base that on? |
mb911 |
Aug 28 2019, 04:08 PM
914 Guru Group: Members Posts: 6,850 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
QUOTE Sounds like a bit much for narrow body Over 175 horse . should be flared ...5lug... Sc suspension Big tires/brakes ...etc (IMG:style_emoticons/default/idea.gif) That's an awfully specific number - what do you base that on? I think it is based off of this write up.. http://www.914world.com/bbs2/index.php?showtopic=105728 |
Aug 28 2019, 05:02 PM
What’s great about the 914 get togethers,is you get to see all the different ways of building the “perfect” 914. There’s no one best way.
Chi-town |
Aug 28 2019, 05:04 PM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
Great comparison on the 2.5 914 and the 2.0 WRX STI. I think 200-250hp mark on the 914 is about right! Thanks Sounds like a bit much for narrow body Over 175 horse . should be flared ...5lug... Sc suspension Big tires/brakes ...etc I'll be on a very sticky 215 tire under my narrow body with 260hp (IMG:style_emoticons/default/biggrin.gif) |
thelogo |
Aug 28 2019, 06:06 PM
QUOTE Sounds like a bit much for narrow body Over 175 horse . should be flared ...5lug... Sc suspension Big tires/brakes ...etc (IMG:style_emoticons/default/idea.gif) That's an awfully specific number - what do you base that on? Based off of ... Stock brakes will no longer be up to the task with that much power |
Aug 28 2019, 07:07 PM
QUOTE Sounds like a bit much for narrow body Over 175 horse . should be flared ...5lug... Sc suspension Big tires/brakes ...etc (IMG:style_emoticons/default/idea.gif) That's an awfully specific number - what do you base that on? Based off of ... Stock brakes will no longer be up to the task with that much power Brakes don’t deal with power, they relate to mass x velocity. At 75 mph in a 2000lb car, there is no difference stopping a 100hp car or a 500hp car. |
Andyrew |
Aug 28 2019, 07:31 PM
QUOTE Sounds like a bit much for narrow body Over 175 horse . should be flared ...5lug... Sc suspension Big tires/brakes ...etc (IMG:style_emoticons/default/idea.gif) That's an awfully specific number - what do you base that on? Based off of ... Stock brakes will no longer be up to the task with that much power Brakes don’t deal with power, they relate to mass x velocity. At 75 mph in a 2000lb car, there is no difference stopping a 100hp car or a 500hp car. (IMG:style_emoticons/default/agree.gif) |
Aug 28 2019, 08:13 PM
Resident German Group: Admin Posts: 41,637 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Brakes don’t deal with power, they relate to mass x velocity. At 75 mph in a 2000lb car, there is no difference stopping a 100hp car or a 500hp car. (IMG:style_emoticons/default/agree.gif) Brakes relate to power in the sense that more power makes it a lot easier to do all that stupid stuff that one needs good brakes for ... (IMG:style_emoticons/default/shades.gif) |
thelogo |
Aug 28 2019, 09:09 PM
QUOTE Sounds like a bit much for narrow body Over 175 horse . should be flared ...5lug... Sc suspension Big tires/brakes ...etc (IMG:style_emoticons/default/idea.gif) That's an awfully specific number - what do you base that on? Based off of ... Stock brakes will no longer be up to the task with that much power Brakes don’t deal with power, they relate to mass x velocity. At 75 mph in a 2000lb car, there is no difference stopping a 100hp car or a 500hp car. Put down the engineering degree or dust it off (Mass x velocity) (IMG:style_emoticons/default/smoke.gif) Common sense ...bigger engine /more power/more weight is usually going to require more stopping power. (IMG:style_emoticons/default/wub.gif) (IMG:style_emoticons/default/bye1.gif) |
cali914 |
Aug 28 2019, 09:36 PM
cali914 Group: Members Posts: 447 Joined: 26-April 06 From: Berkeley Ca. Member No.: 5,934 Region Association: Northern California |
Here’s the best comparison of a 2.0 vs a 3.2 ill second that (IMG:style_emoticons/default/smoke.gif) |
Coondog |
Aug 28 2019, 09:40 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
If you want your car to stop faster, an intuitive start may be to upgrade your brakes. While it may sound logical, for everyday driving it will probably have no effect on your actual stopping distance. Brakes are the system responsible for turning the kinetic energy of your moving car into heat (science talk for slowing it down), however the car’s tires are ultimately responsible for how quickly this occurs. Like I always say brakes stop the wheels but tires stop the car........... (IMG:style_emoticons/default/first.gif) |
rick 918-S |
Hey nice rack! -Celette Group: Members Posts: 20,458 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Brakes don’t deal with power, they relate to mass x velocity. At 75 mph in a 2000lb car, there is no difference stopping a 100hp car or a 500hp car. (IMG:style_emoticons/default/agree.gif) Brakes relate to power in the sense that more power makes it a lot easier to do all that stupid stuff that one needs good brakes for ... (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/agree.gif) a big part of adding weight is adding larger wheels and tires. Unsprung weight spinning with a larger contact patch. Think about the wheel as a lever The longer lever and the larger the crank handle the more clamping force is required to counter the weight and force. This is whether you have 100 go or 450 go. HP only matters if you package increases force of the lever through weight and leverage. |
Lo-Fi Version | Time is now: 15th May 2024 - 05:37 PM |
