Door jamb |
Door jamb |
partwerks |
Sep 2 2019, 09:36 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
In the door jamb, there is a plate with a rubber piece that is in it. What is that rubber part called?
914_7T3 |
Sep 2 2019, 09:43 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,846 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
Not sure, but I think it comes with the Striker Plate as a single part.
914_7T3 |
Sep 2 2019, 09:45 PM
Delete
Mikey914 |
Sep 3 2019, 05:38 AM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
It’s part of the jamb catch assembly. Try classified section I’d bet there are a few laying around.
914Sixer |
Sep 4 2019, 07:07 AM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Most break off when you try removing them from the latch catch. West Coast Metric used to make them but I think they are NLA.
bdstone914 |
Sep 4 2019, 07:34 AM
bdstone914 Group: Members Posts: 4,514 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@partwerks
QUOTE In the door jamb, there is a plate with a rubber piece that is in it. What is that rubber part called? They are called striker plates. There are replacement rubber parts but the ones I got did not fit well. Too loose. Do you need them or just asking the name. I have dozens. There are many variations but they are all interchangeable . Early 1970 -72 had ones that attached with screws. Later ones had protrusions that snapped in. Most break removing them. You need to get them hot to remove the rubber. And pry them out in a special way to not tear them. I replate them with the rubber in place. |
bdstone914 |
Sep 4 2019, 07:37 AM
@914Sixer
Airhead parts has them. They fit loose. I bough a bunch of them. Not mmn ade correctly. QUOTE Most break off when you try removing them from the latch catch. West Coast Metric used to make them but I think they are NLA. |
bbrock |
Sep 4 2019, 07:55 AM
I'm not happy to hear they may not fit well because I need to replace mine, but the late ones are VW part # 311837177A and available several places.
shane |
Sep 4 2019, 02:10 PM
Member Group: Members Posts: 355 Joined: 12-February 13 Member No.: 15,518 Region Association: None |
Mikey914 |
Sep 4 2019, 11:04 PM
If the parts available are crap or non existent, we can make them, but it will take me a little time to get to them. We have a massive new project we are try to get wrapped up.
Jett |
Sep 4 2019, 11:34 PM
Senior Member Group: Members Posts: 1,636 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
I need these as well and ordered a pair from two different vendors... we will see (IMG:style_emoticons/default/smile.gif)
mepstein |
Sep 5 2019, 05:28 AM
914-6 GT in waiting Group: Members Posts: 19,244 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I need these as well and ordered a pair from two different vendors... we will see (IMG:style_emoticons/default/smile.gif) I need some too. Please let me know your results. |
bdstone914 |
Sep 5 2019, 06:16 AM
I need these as well and ordered a pair from two different vendors... we will see (IMG:style_emoticons/default/smile.gif) Pleas let us know how well they fit. There is a right and wrong way to install them. One of the tabs at the top is more simple in shape and goes in last. Heating them in a cup of hot water helps removal and installation. Bruce |
partwerks |
Sep 5 2019, 08:17 PM
Jett |
Oct 10 2019, 10:39 PM
I need these as well and ordered a pair from two different vendors... we will see (IMG:style_emoticons/default/smile.gif) Pleas let us know how well they fit. There is a right and wrong way to install them. One of the tabs at the top is more simple in shape and goes in last. Heating them in a cup of hot water helps removal and installation. Bruce The pair from eBay have not arrived yet, but the airhead part looks good and is easy to install. https://airheadparts.com/vw-part/rubber-wed...plate-l-or-r-2/ |
Rob-O |
Oct 10 2019, 11:33 PM
Senior Member Group: Members Posts: 1,251 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Jett |
Oct 11 2019, 01:36 PM
pics...
Attached image(s) |
Jett |
Oct 17 2019, 09:00 AM
I received the stock stoppers from VW yesterday and they are just like the originals. Hard plastic and a perfectly oriented white cap.
Harder to put on than the aftermarket but will probably last longer. |
rgalla9146 |
Oct 17 2019, 04:54 PM
Advanced Member Group: Members Posts: 4,545 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Lo-Fi Version | Time is now: 28th April 2024 - 02:10 AM |
