center console clock solution at last, perfect fit quartz |
dr914@autoatlanta.com |
Sep 30 2019, 04:03 PM
914 Guru Group: Members Posts: 7,850 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
We have finally made a clock to match the center console volt meter, oil temp gauge, and optional (for us ) oil pressure gauge. These are perfect fit center console size not the aftermarket smaller ones. Clock is 49.50 introductory price for club members. How many are interested?
We will now have a complete console package factory duplicate center console three factory look gauges console heater switch wiring harness (thank you Jeff Bowlsby) |
Oct 1 2019, 12:09 PM
ok I will put together a link and all who are interested can order, obviously as usual you will not be charged until the part is on the dock and ready to ship
drem914 |
Oct 1 2019, 04:33 PM
Senior Member Group: Members Posts: 1,030 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California |
ok I will put together a link and all who are interested can order, obviously as usual you will not be charged until the part is on the dock and ready to ship Does the clock just plug in to the old harness attachment point or is a new harness required to replace the clock. Is the harness for those that did not have the center console in the first place? I am a bit confused (IMG:style_emoticons/default/confused24.gif) |
Oct 2 2019, 08:07 AM
Jeff's harness just plugs into this clock, and the short harness then plugs into the main wiring harness located under the center tunnel carpet (on all 73-76 models). For the earlier cars we include a schematic showing where to tap the 70-72 wiring harness in the correct places to power the console gauges (like the brake pedal switch for one place!!)
rjames |
Oct 2 2019, 10:55 AM
I'm made of metal Group: Members Posts: 3,928 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Jeff's harness just plugs into this clock, and the short harness then plugs into the main wiring harness located under the center tunnel carpet (on all 73-76 models). For the earlier cars we include a schematic showing where to tap the 70-72 wiring harness in the correct places to power the console gauges (like the brake pedal switch for one place!!) ok I will put together a link and all who are interested can order, obviously as usual you will not be charged until the part is on the dock and ready to ship Does the clock just plug in to the old harness attachment point or is a new harness required to replace the clock. Is the harness for those that did not have the center console in the first place? I am a bit confused (IMG:style_emoticons/default/confused24.gif) I'm still confused. Maybe it's because I haven't had my morning coffee yet. I have a later '75 car that already as a connected center console. Will the clock plug right in to my existing wiring, or do I need to buy another harness to make this work? |
Mikey914 |
Oct 2 2019, 11:56 PM
The rubber man Group: Members Posts: 12,660 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Jeff's harness just plugs into this clock, and the short harness then plugs into the main wiring harness located under the center tunnel carpet (on all 73-76 models). For the earlier cars we include a schematic showing where to tap the 70-72 wiring harness in the correct places to power the console gauges (like the brake pedal switch for one place!!) ok I will put together a link and all who are interested can order, obviously as usual you will not be charged until the part is on the dock and ready to ship Does the clock just plug in to the old harness attachment point or is a new harness required to replace the clock. Is the harness for those that did not have the center console in the first place? I am a bit confused (IMG:style_emoticons/default/confused24.gif) I'm still confused. Maybe it's because I haven't had my morning coffee yet. I have a later '75 car that already as a connected center console. Will the clock plug right in to my existing wiring, or do I need to buy another harness to make this work? I'm assuming these are like the factory so they should plug right into the factory harness. |
Lo-Fi Version | Time is now: 12th May 2024 - 01:11 PM |
