center console clock solution at last, perfect fit quartz |
dr914@autoatlanta.com |
Oct 1 2019, 02:51 PM
914 Guru Group: Members Posts: 7,820 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Oct 1 2019, 02:53 PM
the complete package, console, harness, console heater switch lever, volt, temp, clock, three rubber wedge boots, 495.00. (sending unit for temp, sending unit plate, and oil pressure gauge, extension hose or sending unit for oil pressure optional (one can substitute the oil pressure gauge for one of the other gauges however
914werke |
Oct 1 2019, 03:00 PM
"I got blisters on me fingers" Group: Members Posts: 10,027 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Does it include the little plastic lever surround & lighted indicator? (IMG:style_emoticons/default/idea.gif)
drem914 |
Oct 1 2019, 04:33 PM
Senior Member Group: Members Posts: 1,029 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California |
ok I will put together a link and all who are interested can order, obviously as usual you will not be charged until the part is on the dock and ready to ship Does the clock just plug in to the old harness attachment point or is a new harness required to replace the clock. Is the harness for those that did not have the center console in the first place? I am a bit confused (IMG:style_emoticons/default/confused24.gif) |
Mikey914 |
Oct 1 2019, 11:31 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Got the harnesses in stock that if George needs them we can provide. Later cars these plug right in. Could discount some for GB and can ship to AA or drop ship (IMG:style_emoticons/default/dry.gif) Mark if I read George's post correctly it looks as though our own Jeff B is providing the harnesses (IMG:style_emoticons/default/confused24.gif) Sorry missed it, You can see it now that you pointed it out, but wit was on the picture side. |
Oct 2 2019, 08:07 AM
Jeff's harness just plugs into this clock, and the short harness then plugs into the main wiring harness located under the center tunnel carpet (on all 73-76 models). For the earlier cars we include a schematic showing where to tap the 70-72 wiring harness in the correct places to power the console gauges (like the brake pedal switch for one place!!)
rjames |
Oct 2 2019, 10:55 AM
I'm made of metal Group: Members Posts: 3,916 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Jeff's harness just plugs into this clock, and the short harness then plugs into the main wiring harness located under the center tunnel carpet (on all 73-76 models). For the earlier cars we include a schematic showing where to tap the 70-72 wiring harness in the correct places to power the console gauges (like the brake pedal switch for one place!!) ok I will put together a link and all who are interested can order, obviously as usual you will not be charged until the part is on the dock and ready to ship Does the clock just plug in to the old harness attachment point or is a new harness required to replace the clock. Is the harness for those that did not have the center console in the first place? I am a bit confused (IMG:style_emoticons/default/confused24.gif) I'm still confused. Maybe it's because I haven't had my morning coffee yet. I have a later '75 car that already as a connected center console. Will the clock plug right in to my existing wiring, or do I need to buy another harness to make this work? |
914werke |
Oct 2 2019, 12:11 PM
As I understand it these are reproductions. Clock, harness, console...
George? |
Mikey914 |
Oct 2 2019, 11:56 PM
Jeff's harness just plugs into this clock, and the short harness then plugs into the main wiring harness located under the center tunnel carpet (on all 73-76 models). For the earlier cars we include a schematic showing where to tap the 70-72 wiring harness in the correct places to power the console gauges (like the brake pedal switch for one place!!) ok I will put together a link and all who are interested can order, obviously as usual you will not be charged until the part is on the dock and ready to ship Does the clock just plug in to the old harness attachment point or is a new harness required to replace the clock. Is the harness for those that did not have the center console in the first place? I am a bit confused (IMG:style_emoticons/default/confused24.gif) I'm still confused. Maybe it's because I haven't had my morning coffee yet. I have a later '75 car that already as a connected center console. Will the clock plug right in to my existing wiring, or do I need to buy another harness to make this work? I'm assuming these are like the factory so they should plug right into the factory harness. |
Oct 3 2019, 07:49 AM
yes all are reproductions. We made our factory console from the original aluminum cutting boards, but it has thicker wood also factory match material and real stitching rather than heat seamed like the original
As I understand it these are reproductions. Clock, harness, console... George? |
rjames |
Oct 16 2019, 11:09 AM
George, what is the status on these?
914werke |
Oct 16 2019, 11:12 AM
The link is to a store item not a list?
Is this a pre-payment? |
Oct 16 2019, 11:21 AM
TonyA |
Oct 16 2019, 02:28 PM
Nachmal Group: Members Posts: 460 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States |
Interested if it will plug into an original harness. Should have had the hands saying 9:14
914werke |
Dec 5 2019, 12:05 PM
absolutely not, just a pre order then when on the dock with a tracking number we charge due in before the end of the year, many of them The link is to a store item not a list? Is this a pre-payment? EOY is fast approaching (IMG:style_emoticons/default/dry.gif) Any update? |
Dec 5 2019, 12:43 PM
rjames |
Dec 5 2019, 02:48 PM
I received mine a while back and am pretty happy with it. Although it is not an exact match- the bezel is slightly different and of course it doesn't say 'vdo' on the gauge face. Also the connector on the stock harness for the light does not fit, so modification is necessary if you want the gauge to light up.
I will probably swap the bezel out for the one on my non-working clock as it bugs me whenever I look at it. All that said, it does look very good and is still ticking. Appreciate this product being provided. |
914werke |
Dec 5 2019, 04:12 PM
HUH? @rjames So these are shipping? What am I missing? If I read/interpret Georges response
correctly hes got no stock and is sitting on orders prior to ordering.... |
Coondog |
Dec 5 2019, 04:39 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
HUH? So these are shipping? What am I missing? If I read/interpret Georges response correctly hes got no stock and is sitting on orders prior to ordering.... I heard this same story from AA 2 plus years ago. Got tired of waiting and moved on. (IMG:style_emoticons/default/mad.gif) |
914werke |
Dec 5 2019, 05:26 PM
I just went back to the beginning of this thread & NO where is it indicated that this "deal" was contingent ...on anything
Lo-Fi Version | Time is now: 26th April 2024 - 11:01 PM |
