GB engine tin delete plugs Closes 12/31/19, PN 914.559.243.10 $6 a pair Confirmed These fit perfectly LIke OEM |
Mikey914 |
Dec 9 2019, 02:37 AM
The rubber man Group: Members Posts: 12,660 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
These are the delete plugs used on the 914/6 to eliminate the rain tubes as there is no rain tray on it.
They are also used on the early cars including 73 from what I can see on PET Stopper -73 1 914-4/1,7 for 914-2,0 Oil hose And Water drain sleeve 13 Stopper -73 2 914-6 for Oil hose And Water drain sleeve These are located in the Hell hole area and under the relay board. I'll post pictures up Monday afternoon, but if you have holes there these are what should be plugging them They are not on the low point, but on the part sloping down. Made from Nylon to the correct dimension like factory not a cheap plug that kind of fits At $6 a pair who's in? |
BeatNavy |
Dec 9 2019, 07:01 AM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
Do you have a pic of what they are supposed to look like? I found something like what you're describing all covered in undercoating, so I thought maybe it was some sketchy repair the DAPO did or something. Glad to hear it may be legit.
What the hey, I'm in for at least a pair. |
Mikey914 |
Dec 9 2019, 10:02 AM
Do you have a pic of what they are supposed to look like? I found something like what you're describing all covered in undercoating, so I thought maybe it was some sketchy repair the DAPO did or something. Glad to hear it may be legit. What the hey, I'm in for at least a pair. I'll post up shortly, but yes most of there are missing or covered over with crap if they are still there. Just another part you didn't know you even needed (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 13th May 2024 - 12:16 AM |
