GB engine tin delete plugs Closes 12/31/19, PN 914.559.243.10 $6 a pair Confirmed These fit perfectly LIke OEM |
Mikey914 |
Dec 9 2019, 02:37 AM
The rubber man Group: Members Posts: 12,660 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
These are the delete plugs used on the 914/6 to eliminate the rain tubes as there is no rain tray on it.
They are also used on the early cars including 73 from what I can see on PET Stopper -73 1 914-4/1,7 for 914-2,0 Oil hose And Water drain sleeve 13 Stopper -73 2 914-6 for Oil hose And Water drain sleeve These are located in the Hell hole area and under the relay board. I'll post pictures up Monday afternoon, but if you have holes there these are what should be plugging them They are not on the low point, but on the part sloping down. Made from Nylon to the correct dimension like factory not a cheap plug that kind of fits At $6 a pair who's in? |
sixnotfour |
Dec 9 2019, 10:33 AM
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
(IMG:style_emoticons/default/beerchug.gif) plus one more -73 where the six oil line goes through shelf to lower tank fitting,,, right side of pic.,If not a six..
Attached image(s) |
Mark Henry |
Dec 9 2019, 11:54 AM
(IMG:style_emoticons/default/beerchug.gif) plus one more -73 where the six oil line goes through shelf to lower tank fitting,,, right side of pic.,If not a six.. (IMG:style_emoticons/default/agree.gif) That's one I'd definitely be interested in. |
Lo-Fi Version | Time is now: 12th May 2024 - 10:13 PM |
