GB engine tin delete plugs Closes 12/31/19, PN 914.559.243.10 $6 a pair Confirmed These fit perfectly LIke OEM |
Mikey914 |
Dec 9 2019, 02:37 AM
The rubber man Group: Members Posts: 12,660 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
These are the delete plugs used on the 914/6 to eliminate the rain tubes as there is no rain tray on it.
They are also used on the early cars including 73 from what I can see on PET Stopper -73 1 914-4/1,7 for 914-2,0 Oil hose And Water drain sleeve 13 Stopper -73 2 914-6 for Oil hose And Water drain sleeve These are located in the Hell hole area and under the relay board. I'll post pictures up Monday afternoon, but if you have holes there these are what should be plugging them They are not on the low point, but on the part sloping down. Made from Nylon to the correct dimension like factory not a cheap plug that kind of fits At $6 a pair who's in? |
Mikey914 |
Dec 17 2019, 05:54 PM
GB PMs sent to all so for, parts are done and ready to ship. These are set up as individuals and it defaults to a set of 2
I'll keep open the GB til the endo of the year. There is a GB for trailing arm bushings that I will be ready to start PM'ing on Monday, so if you want to combine you can hold tight and we can ship in one order. Thanks to all https://900designs-container.zoeysite.com/s...and-body-panels Attached thumbnail(s) |
Lo-Fi Version | Time is now: 13th May 2024 - 07:05 AM |
