GB engine tin delete plugs Closes 12/31/19, PN 914.559.243.10 $6 a pair Confirmed These fit perfectly LIke OEM |
Mikey914 |
Dec 9 2019, 02:37 AM
The rubber man Group: Members Posts: 12,660 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
These are the delete plugs used on the 914/6 to eliminate the rain tubes as there is no rain tray on it.
They are also used on the early cars including 73 from what I can see on PET Stopper -73 1 914-4/1,7 for 914-2,0 Oil hose And Water drain sleeve 13 Stopper -73 2 914-6 for Oil hose And Water drain sleeve These are located in the Hell hole area and under the relay board. I'll post pictures up Monday afternoon, but if you have holes there these are what should be plugging them They are not on the low point, but on the part sloping down. Made from Nylon to the correct dimension like factory not a cheap plug that kind of fits At $6 a pair who's in? |
gandalf_025 |
Jan 16 2020, 08:19 AM
Senior Member Group: Members Posts: 1,453 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States |
These arrived the other day with the A-Arm bushings.
I just walked out into the garage and popped them in.. They fit perfect.. They snap in with a little pressure. Thanks again for making parts like these.. My originals were pretty nasty looking.. |
Mikey914 |
Feb 6 2020, 07:22 PM
These arrived the other day with the A-Arm bushings. I just walked out into the garage and popped them in.. They fit perfect.. They snap in with a little pressure. Thanks again for making parts like these.. My originals were pretty nasty looking.. Your welcome and thanks to all that participated to help get these made! (IMG:style_emoticons/default/beer3.gif) |
Lo-Fi Version | Time is now: 12th May 2024 - 11:11 PM |
